3 Pages 123>
Klear or not as the case maybe.... Options
RobbieP
#1 Posted : 09 January 2013 21:38:29
Ive recently used Klear on the front suspension unit before applying the decals. I applied it by brush and think I may have left it on too long as it went really hard and I ended up scraping the stuff off again before applying anything.Mad Did I do something else wrong apart from leaving it on too long? Also Ive found now the decals are drying out they look fine apart from the edges lifting and so not moulding around the suspension, what can I use to get them to mould? Its only minor little things but Ive come so far I just like the little details to be right. Any help would be gratefully recieved.....thankyou
McLaren MP4/23
Ducati 998
#2 Posted : 09 January 2013 23:16:01
I can't quite understand what you did wrong with Klear.....
It's just a very thin but smooth acrylic coating. I've never had issues with it. I'm not sure what you mean about 'leaving it too long'.....
It just dries after 15 mins or so - that's it.
To get the decals to 'fix' at the edges etc, use Microsol. It's great stuff.
Apply the decal, coat with a brushload of Microsol and leave it. The decals will fit to any contours. Then (when dry!) coat again with Klear.
Roy.
RobbieP
#3 Posted : 09 January 2013 23:23:12
ok, as ever thanks Roy, Im coming to the conclusion Im either going mad or I had something on the brush that I wasnt aware of. I'll try againBigGrin
McLaren MP4/23
Ducati 998
metallica155
#4 Posted : 10 January 2013 10:09:43
You didn't make an error with the Klear itself, its brush on and leave.
The error was putting it on before the decals, they would have not been able to adhere properly to the Klear finish.
As RMB says above, apply the decals using Microsol/Microset to get them to mould to the body contours, then apply Klear once the decals have fully dried
Warthog
#5 Posted : 11 January 2013 18:51:39
Agree with this.. Klear goes on after the Decal not before
Wilfy the Sea Dog
#6 Posted : 11 January 2013 19:37:44
I always apply Klear before decaling to achieve a nice gloss finish for them to adhere to & it works fine. I recoat when dry to protect. I don't think Klear is your issue. Think you should definatly use the Microsol/Microset as receommend already.
Wilfy
only1ianuk
#7 Posted : 11 January 2013 22:48:21
I used Mr Hobby Clear Coat and its amazing! So easy to use as well!! Definately recommend!!!
RobbieP
#8 Posted : 12 January 2013 10:46:03
thank you all for your words of wisdom, its reassuring to know thst even now at this late stage there is still help out there...'Warty' you continue to be an inspirationDrool and Ian your tip on Hobby 'clearcoat' nice...BigGrin a big thank you
McLaren MP4/23
Ducati 998
Warthog
#9 Posted : 12 January 2013 15:42:33
Ah your too kind!! Cool
davyp1
#10 Posted : 14 January 2013 21:28:17
Red Medal: Red Medal
I didnt have much luck with klear myself.Left milkly stains everywhere ended up just taking it all off again.Crying S
hes in the spray booth now ready for some clear coat.BigGrin
RobbieP
#11 Posted : 15 January 2013 20:27:32
yes David, that was the same with me milky stains and then dryness that looks like dried glueAngry Ill see if I can put up a photo to show you what I mean..
McLaren MP4/23
Ducati 998
RobbieP
#12 Posted : 15 January 2013 20:55:21
the picture sort of shows you what I meant...could be a case of taking them off and ordering newMad
McLaren MP4/23
Ducati 998
Warthog
#13 Posted : 15 January 2013 23:18:46
Hi Robbie
I'm trying to understand what has gone wrong here Confused First i need to understand how you are applying the decals and secondly the amount of drying time that your giving the decals?? If your appliyng the decals with a solution like MicroSol or the revell one then I can't see how your getting the decals uplifting as they are from the picture..
Decals should be left to dry overnight and then the Klear applied evenly and sparingly to give a single coat at a time.. leave to dry and repeat... the next day if necessary.
I know we all have different degrees of expertise and to some this method of applying Klear can be daunting to some beginners but may I suggest that when you get your new decals (or remove the old ones in warm soapy water) and leave the suspension in its original black? I think you will be happier in the long run ( I'm not too fond of the decals myself to be honest)
Spencer
driving4life
#14 Posted : 16 January 2013 00:17:02
Rank: Amateur Level 1
Hi, is this just for decals or is this to apply to give it a shine to the whole of the model including silver and red parts of the model ?
cheers
RobbieP
#15 Posted : 16 January 2013 00:41:01
thanks for your comments Warty, what I did was apply by brush a coating of Klear and left it thinking the decals would adhere to it and follow the contours of the suspension then, after the application and about 5-10 mins I used warm water to detach the decals and applied them to the suspension...no Micro-Sol just Klear before hand and warm water for the decals. I think youre right, going back to the plain black would be better, I was much happier before I applied the decals and for my first attempt pleased with the results until then so, tomorrow its out with the warm soapy water and off they come. The ones on the rear suspension are fine does it mean I'll have to take them off too?Cryingthank you again for your support...its appreciatedBigGrin
McLaren MP4/23
Ducati 998
Warthog
#16 Posted : 16 January 2013 19:28:00
Hi Robbie
Ok I can see how you have become confused Crying Klear is NOT a setting solution. Klear is a polish to add a protective coating to the decal once it is dry. It's a floor polish but it is used by modellers too Aircraft Canopies and sometimes to protect the paint.
From what your saying is your using it as a setting solution rather than the MicroSol that some here are using.. Easy mistake to make my friend and it can be confusing to some who have never used it before.. Imagine it as a TOP COAT and nothing more.
If you do get new Decals then just apply as in Tomick's Official Build, Warm water and nothing else
I'll PM you and give you my Mobile so if you fancy a chat from a fellow Cornishman then I'll be happy to help
Spencer
Warthog
#17 Posted : 16 January 2013 19:32:29
cheers
Hi
It can be used for the whole of the model but there needs to be a certain amount of skill involved...
Please don't think I'm saying you don't have the skill to do this but unless used in the correct way, you could end up messing it up
PM me if you need to ask any more Q's and I will be more than happy to help
Spencer
Warthog
#18 Posted : 16 January 2013 19:43:31
Here is a VIDEO on how to apply Klear... In the US its called Pledge (they like to be different!)
Don't forget you will get different results due to the type of car your adding it too but follow the basic process and you should have no problems.. Just a tip.. when buffing use a Lint Free cloth (new) and do not press to hard.. You might have to add another coat but do this once the first coat has fully dried (as in a few hours)
Spencer
#19 Posted : 16 January 2013 19:49:32
I use an airbrush to apply Klear. Brilliant stuff!!!!BigGrin
Warthog
#20 Posted : 16 January 2013 19:52:34
It Is great stuff once mastered.. Welcome to the forum Nemesis ThumpUp
Spencer
Guest (7)
3 Pages 123>
This page was generated in 0.360 seconds.
