5 Pages 123>»
launch build Options
timebob
#1 Posted : 15 May 2010 18:18:15
Rank: Beginner Level 3
hay ship mates just done the launch very tricky not all the tabs fit
into the slots lots of filing to be done.
snowtiger
#2 Posted : 16 May 2010 01:41:27
Looks like you are off to a good start..Timebob...BigGrin BigGrin BigGrin
jay7792
#3 Posted : 16 May 2010 16:15:18
Looks really good mate, well doneBigGrin
_____________________________________
Currently building:-
Deagostini HMS Victory
Amati Black Pearl
Mamoli HMS Victory 1:90 Scale
Caldercraft HMS Victory 1:72
comic123
#4 Posted : 16 May 2010 19:08:34
BigGrin nice jobBigGrin
john burgess
#5 Posted : 19 May 2010 16:23:45
Looks a "OK" keep up the good work matey, not like me snap No12 he he lol
If you dont suceed at first go to the pub
Admiral Langley
#6 Posted : 27 May 2010 21:30:13
Hiya Shipmates, Just Started doing it myself, looks good mate, hope mine looks like that.lol
dtgray
#7 Posted : 28 May 2010 19:10:58
Welcome aboard BigGrin
David
eoinkm
#8 Posted : 01 June 2010 17:08:57
Rank: Amateur Level 1
Hi guys,
I have just attempted to build the launch however I failed miserably and snapped part #4, so didn't get very far.
This is, as you can imagine, quite frustrating.
How do you order the parts again?
Thanks
Mike Turpin
#9 Posted : 01 June 2010 17:30:06
Hi there
Several of us have had a similar experience -- the ribs are quite fragile. Before you re-order part 6, have you considered sticking the broken parts together with some super glue? If you can get the ends to come together, the strength of the bond should be greater than the surrounding wood. Once you start planking the ribs you will find that the whole thing gains strength and rigidity. It's at least worth a try and is an advantage of working in wood.
If you haven't found this yet it might be useful to you. Launch Construction
Welcome to the mad house
Cheers
Mike T
gaffa1963
#10 Posted : 01 June 2010 20:40:11
Hope this question does not sound stupid as i am new to building models out of wood do you plank the launch with super glue and if you do do you use the thick glue as i have heard someone mention super glue gel and when i asked at the model shop they said it was thick super glue not gel
Dave
budgie
#11 Posted : 01 June 2010 21:02:22
Dave
the super glue i got from b&q is called super glue gel
prob same as the thick type
i will be using aliphatic glue for 2nd attempt at launch so i can have a bit of time for corrections
snowtiger
#12 Posted : 01 June 2010 21:06:20
Budgie ...there are 3 types of super glue.....and they go by the mental name ..Viscosity....if your local model give you the blank look then check out e-bay....thats where i get mine ....and it's cheaper..BigGrin BigGrin BigGrin
willie
#13 Posted : 01 June 2010 21:08:49
Dave
there is three types of super glue thin ,medium and thick, thicker it is the longer its takes to set ,the white glue gives you more time to make adjustments
Mike Turpin
#14 Posted : 01 June 2010 21:11:43
I have used the B & Q super glue gel but when I was ordering from Cornwall Model Boats, I ordered their thick super glue.
This is much easier to control than the thin glue which runs everywhere but is not as thick as the gel. It is now my super glue of choice for modelling.
Mike T
Zeptrader
#15 Posted : 01 June 2010 21:14:36
Evening Mike and all:)
I have to agree with Mike again, I have all 3 of the cornwall boat models super glue (thick, medium & thin), the thinner glue would suit the rigging, the thicker as Mike says would suit the planking and again using less.
snowtiger
#16 Posted : 01 June 2010 21:15:27
Thanks for the tip Mike....i have got superglue from different places and they have varied ....looks like i will be buying from cornwall models in future...BigGrin BigGrin
#17 Posted : 02 June 2010 10:06:25
Cyano or Superglue as it is more commonly known, shouldn't be used for sealing knots on rigging thread unless your very familiar with the thread quality. Cyano has a tendancy to soak through threads, with the end result being that the thread can become brittle and snap, if in doubt don't use Cyano, use diluted PVA.
#18 Posted : 02 June 2010 10:12:20
Ahhhh!!!!!!!!!!
Looks like I'm goosed then, I've secured most my knots on the San Francisco II with thick super-glue from Cornwall models(Caldercraft).
Chris...
#19 Posted : 02 June 2010 11:15:25
Not necessarily, it depends on the thread type used, though over time normal cyano has a tendancy to become very brittle where a jolt might mean the bond parts company, though there are some cyano types around such as Loctite's ULTRA Gel, which is a specially formulated rubber toughened cyano that resists impact, shock, vibration and temperature extremes, its also outdoor safe and gives more time to align pieces before the glue takes hold.
eoinkm
#20 Posted : 02 June 2010 12:50:10
Mike Turpin wrote:
Hi there
Cheers
Mike T
Thanks Mike for your words of wisdom. I did actuall try and stick the parts back together but I felt I wasn't getting the result. How do I Re-order part 6?
Thanks
Eoin
5 Pages 123>»
This page was generated in 0.089 seconds.
