21 Pages «<45678>»
Karl's Sovereign of the Seas Options
#101 Posted : 21 January 2013 17:24:57
thank you gents for the kind comments,and a little explaining is needed I think,first of all,apologies for the bad pics,I've drop my camera and is broke,so the I-pad had to step in.
the pencil lines you can see are where I have tapered and beveled the planks,not sure yet where to terminate the ll.e.ds.but hope to have contacts on the keel which will work from the stand.
#102 Posted : 26 January 2013 10:48:35
that's the lower hull planked,and now for the big sand off,of all the jobs in building a ship,this has got to be the messiest,s.w.m.b.o. ALWAYS moans about the saw dust gets everywhere.Huh
#103 Posted : 26 January 2013 12:01:35
Hi Karl,
Nice build looking forward to more pictures,love the lights,good stuff.
Regards Trev.
#104 Posted : 26 January 2013 16:28:28
thanks trev,heres some more after sanding.
#105 Posted : 26 January 2013 16:30:19
sorry the pics are upside down,I'm no photographer.
court orchard
#106 Posted : 26 January 2013 16:42:10
No, but I'm impressed you can stand on your head whilst you're taking themLOL
Nice work on the planking, by the way.
#107 Posted : 26 January 2013 18:10:25
cheers andy,me a bit old for all that break dancingConfused
budgie
#108 Posted : 26 January 2013 18:28:04
BigGrin Hi Karl she's coming along nicely
I follow ALL your build diaries and i have been meaning to ask you
"why with this project did you decided to balsa the full length?"
as in previous builds you have not bothered and just relied on your knowledge and expertise and on other occassions you have just done the bow and stern and they have all turned out nicely
Cheers
#109 Posted : 26 January 2013 20:54:53
hi bodge m8,I would like to know that my self,I just thought I would try it
to see what all the fuss is about,won't be doing it again though,waste of good money,with a little care it is not needed and can cause problems if done too soon,you do need the deck to be in place for it to not cause problems.to be fair,it does help when your planking the bow,it gives a little more surface to stick on, btw love your tanker,and that plank cutter is something else,wanna know why I didn't get a free paintbrush with mine.Love
benny b
#110 Posted : 10 March 2013 19:26:02
hi karl nice and smooth now did you use a machanical sander ?
#111 Posted : 10 March 2013 19:48:15
Hi Karl,
The hull is looking good, I`m only a little way into planking and have found the full balsa infill very helpful as a newbie, but I don`t know how difficult it would be without it, so maybe a bit biased BigGrin .
When you sand the hull, which method do you use, I am looking to get some ideas before I get to that point and would be grateful for your input.
#112 Posted : 10 March 2013 20:39:50
hi benny and del,my method of sanding is in the prep work,I dont like using filler,so I fill any gaps with slivers of wood,then I use a permagrit sanding block,rough one side and fine 'tother,they are expensive but lasts and lasts.I start with rough and remove excess bits of wood filla,then I use the other side of the block which is supposed to be medium but is a little worn now,so it gives a fine sand,any tiny gaps(shrinkage)I use aliphatic glue sanded over,which the sawdust created mixes with the glue to do an invisible join. when the planking is completed I will use shellac sanding sealer,as many coats as it needs with wet and dry carborundum 1200 in between before paint/varnish.
#113 Posted : 10 March 2013 20:56:50
Hi Karl
Thanks for the info, very grateful.
benny b
#114 Posted : 11 March 2013 16:19:57
hi same here karl thanks for update might try not useing filler myself its looking good
#115 Posted : 12 March 2013 08:23:04
Looking good there Karl. Enjoyed your explanation of the balsa infill. I have also been in two minds to do the whole hull or just the stern and bow.Stern and bow win. Your method of filling the gaps also is a way I would like to go in future. Thank you and well done.
#116 Posted : 12 March 2013 08:57:00
hi hans,glad to help,good luck with your builds.
jpda
#117 Posted : 02 April 2013 22:41:31
Rank: Beginner Level 3
Red Medal: Red Medal
karl1113 wrote:
nows the time to sort the lighting,tried various leds and ended up with 3mm.leds,x12v.with a 6v.x1200ma transformer to give the right depth of glow. what's the verdict folks???
these I hope will light the gunports so it looks like light is coming from the lower gun deck,the wiring is .03mm gold jewelers wire,which I got in 6mtr. reels @ £1.75 per reel,and that traversed completely around the gundeck twice so I could solder the leds,and then exiting out the stern to connect to a socket somewhere near by.hopefully I have placed the leds next to the dummy barrels without obscuring them.
Looks great Karl.
Jay
#118 Posted : 17 April 2013 19:26:28
week 32/33, continuing with the planking.
karl1113 attached the following image(s):
#119 Posted : 17 April 2013 20:03:58
Love Hi Karl love the build .The hull is bril lot's of sandingThumpUp .Regard's Martyn
#120 Posted : 17 April 2013 22:56:06
Very nice Karl, nice to see you back on the SOTS build.....BigGrin BigGrin
21 Pages «<45678>»
This page was generated in 0.550 seconds.
