glue for bamboo planks Options
Peter Lewis
#1 Posted : 31 January 2013 15:51:52
Rank: Newbie
Confused I have used alphatic glue but it won't hold the bamboo planks on to the plywood frames can any one tell me which glue holds bamboo fast to the plywood. thank for your help in advance.
#2 Posted : 31 January 2013 16:17:07
Have you lightly sanded the laser-ash from the frame edges which can prevent good adhesion.
I use aliphatic and its okay, a standard PVA wood glue should also be okay
Peter Lewis
#3 Posted : 31 January 2013 16:33:10
Rank: Newbie
Confused yes I have sanded all edges of the frames but the planks were not hard to pull off after 24 hrs drying time.
although the rear counter planks are all held firmly.
#4 Posted : 31 January 2013 16:53:18
Presume you have glued the planks to each other as well as to the frames?
This page was generated in 0.174 seconds.
