Which pin pusher? Options
RobT
#1 Posted : 11 February 2013 13:39:47
A little unsure. With a pin pusher, do the pins only go in as far as you push them or do you need a depth stop if you want to do that?
I'm trying to choose between the Amati and Mantua pin pushers, but don't know if either have a depth stop or of I need one.
#2 Posted : 11 February 2013 14:16:28
I use this one which has a depth stop and is there if you wish to use it and is also a robust item..
http://www.cornwallmodel...g/mantua_nail_fixer.html
RobT
#3 Posted : 11 February 2013 14:21:27
Cheers Mr T, i'll get it ordered.
#4 Posted : 11 February 2013 16:10:56
[quote=Tomick]I use this one which has a depth stop and is there if you wish to use it and is also a robust item..
http://www.cornwallmodel.../mantua_nail_fixer.html[/quote]
Many thanks for the advice. Have just ordered one from cmb.
My existing Amati one has a very weak aluminium tube and is forever getting bent.
The one you use looks a lot stronger.
Kind regards
Tony
This page was generated in 0.665 seconds.
