Hull Planking Options
syd4444
#1 Posted : 11 February 2013 18:46:54
Rank: Amateur Level 1
Would I be right in thinking that when the hull is planked it will be sanded to make it very smooth for the veneer planking. Might seem a silly question, the reason I ask is to gauge how much leeway I have as this is my first time.
#2 Posted : 11 February 2013 20:10:41
BigGrin Hi Syd
you got it in one, from what I can gather from reports on the rounded edges of the bamboo some filler may be used to get it totally smooth ,if and when needed
syd4444
#3 Posted : 11 February 2013 20:30:39
Thanks Andy I thought I would have to use filler. You've my mind at rest.
#4 Posted : 11 February 2013 22:17:07
Hi Syd, would think Mr T will keep us right on whether filler should be used because of the rounded edges of the planks... think we will find out soon enough. Think the finish would need to be spot on before we apply the veneer..... If filler is needed then I for one will be using it.... Good luck, am watching with interest.....Cool Cool
Reagards
This page was generated in 0.630 seconds.
