Catheads Options
PLUTO
#1 Posted : 12 February 2013 11:33:20
HELP: I have just received the Flags and the 'Victory' name transfer. Am I the only one who thinks this is very oversized?. For the model it should only measure 60mm across not 78mm as supplied. I can understand size restrictions when it applies to small items, but there should have been no reason to print the name so large. As it is it will span 5 of the rear windows and not just over 3 as it should. Is it possible to acquire the name anywhere else? John
#2 Posted : 12 February 2013 11:55:02
Catheads?
#3 Posted : 12 February 2013 12:45:54
LOL LOL LOL LOL LOL catheads???????Confused Confused Confused
#4 Posted : 12 February 2013 13:01:23
Hi Pluto.
If you have a PC and scanner you could always scan the oversized items, resize them on any graphics program and then print them onto waterslide transfer paper to make your own. That's how I made mine up (except I had to design it from scratch). You can also use exactly the same procedure with T-shirt iron on transfer paper to make your own flags too! Both types of paper are available through ebay.
Best of luck
PLUTO
#5 Posted : 13 February 2013 12:42:49
Tomick wrote:
Catheads?
Tomick, No - Not Catheads which I now have. I am referring to the oversized 'Victory' name. On the model it should be no more than 60mm. The name' Victory' supplied by DeAgostini measures nearer 80mm. I thought my previous post made this clear that it is too large and I asked if it were possible to get a correct sized one anywhere else. John
PLUTO
#6 Posted : 13 February 2013 12:49:44
Plymouth57 wrote:
Hi Pluto.
Best of luck
Many thanks for that suggestion Robin. I'm glad that I am not the only one that knows the 'Victory' name supplied is oversized. I will endeavour to acquire some waterslide transfer paper and have a go at correcting the problem. I'm certain that there are some standing rigging items misssing from the instructions, when I make compare photo's of 'Victory' in Portsmouth with the completed model - but that's another issue. Thanks again. John
#7 Posted : 13 February 2013 14:22:59
PLUTO wrote:
Tomick wrote:
Catheads?
I think Toms question is around the title of your post which refers to catheads yet the topic is totaly unrelated. Blushing Blink BigGrin LOL
This page was generated in 0.137 seconds.
