Tyre dimensions Options
driving4life
#1 Posted : 12 February 2013 00:14:34
Rank: Amateur Level 1
Hi all
Any ideas on the dimensions of the tyres in mm ?
1. I need the tyres overall circumference
2. opening circumference for where the rim fits
3. width of tyre
and need the same for the back tyres
Thanks
SennaMentalMe
#2 Posted : 14 February 2013 12:38:50
Do you not have a set that you could measure yourself? Hope that doesn't sound derogatory, it isn't meant to be - I just thought it was a strange question to ask if you were building the McLaren yourself, as you should have all the tyres and wheels by now? Confused Huh Blink BigGrin
driving4life
#3 Posted : 17 February 2013 00:24:58
Looking at the tyres I thought I could do it with a tape measure but there are rounded/curved side walls on the tyres which make it a bit more tricky to do. I thought someone may have a technique or tools to calculate this. I might try a digital caliper and see if this does it.
#4 Posted : 17 February 2013 00:52:14
yer,real tricky that one,why o why do they make round wwheels?????beggars up all the measurements,specialy those back ones being so fat an all???same wiv the rims they round as well,gonna invent some squres ones,that should do it,I can measure all day and get it right.......zzzzzzzzzzzzzzzzzzzzz
SennaMentalMe
#5 Posted : 17 February 2013 09:26:40
LOL LOL LOL LOL LOL LOL LOL LOL ThumpUp
Kev Laugh
P.S. A bit of string, a pen and a ruler should do it D4L.
noki49
#6 Posted : 17 February 2013 20:33:06
How about a ruler and a bit of maths. A bit of Pi would be useful.
I do wonder if you havent got the tools/brains to work this out, what you could possibly do with the measurements if you had themConfused
SennaMentalMe
#7 Posted : 17 February 2013 21:06:28
Driving4Life,
Pi = 3.14 (near as damn it) or in the old Imperial scale, 22 over 7 (written as a fraction)
If you want to be really accurate and have a calculator Pi = 3.14159 26535 89793
If you know the radius then the diameter is Pi(3.14) x 2 x Radius(?) then once you have the diameter its D(?) x Pi(3.14) to get the circumference (bl**dy PC text - that is NOT a swear word!!).
You could of course just measure the diameter with a ruler then multiply it by 3.14 (same thing as above!)....
.... or just use a bit of string, a pen and a ruler as I said earlier!! Flapper
Hope that helps? Blink Huh
Why do you want those measurements anyway D4L - just curious?
Judder01
#8 Posted : 17 February 2013 22:54:37
Driving4Life,
If you know the radius then the diameter is Pi(3.14) x 2 x Radius(?) then once you have the diameter its D(?) x Pi(3.14) to get the circomeference (bl**dy PC text - that is NOT a swear word!!).
Think you may have got a little confused Kev. The diameter is simply 2 × radius. The circumference is either diameter × pi or 2 × pi × r (As the diameter is 2r). Also, why do you need these measurements?
Hope this helps,
#9 Posted : 17 February 2013 23:34:52
will you two stop swearing at one another?it;s upsetting me cats,
SennaMentalMe
#10 Posted : 18 February 2013 10:34:13
Driving4Life,
Think you may have got a little confused Kev. The diameter is simply 2 × radius. The circomeference is either diameter × pi or 2 × pi × r (As the diameter is 2r). Also, why do you need these measurements?
Hope this helps,
Hello Judder,
No, I'm not confused, I was just being overly pedantic with my method of finding the diameter which would then allow one to find the radius!! Noki49 suggested that D4L might like to use a little Pi, but I used a lot of Pi (I like Pie!!LOL ). You can check what I say as being correct by searching for 'Circ.umference' (The 'PC' text on this site doesn't like the use of the c.u.m part in the middle of a word by the looks of it!! Confused Glare Mad Flapper ) on Wikipedia, which is what I actually said!!
Of course you yourself are still correct my friend, it IS easier to find the diameter just by using 2r, just thought that as it was a fairly inane question from D4L, then I might have a little fun with it!! You also said - Quote: "The circomeference is either diameter × pi or 2 × pi × r (As the diameter is 2r).Unquote - but if you check my post again that is exactly the same as what I said in the first place!!
No worries though, all's good and like I keep saying - just use a bit of string, a pen and a ruler - simples!!
Karl - LOL LOL LOL LOL
D4L - Why DO you need these measurements anyway? Just curious?
Judder01
#11 Posted : 18 February 2013 11:03:38
Driving4Life,
Hope this helps,
Hello Judder,
You must be getting diameter and circumference (yeah it changes it for me too) confused somehow. The circumference is 2×pi×r (=pi×diameter), NOT the diameter (=2r) which is what you said in your first post.
Hope this clears up my misunderstanding,
Judder
SennaMentalMe
#12 Posted : 18 February 2013 11:22:20
Ooooopps!!!!! Blushing Blushing Blushing Blushing Blink
Just re-read my own post and realised that I didn't write what I meant to say - must get my head checked, though I did type the post late at night after a go on the vino!! LOL LOL
I stand corrected Judder, you win, I lose Blushing - it would appear that I DID say the diameter was Pi x 2 x r didn't I, but as you correctly say, it SHOULD be 2r to get the diameter then x 3.14 to find the circumference (bl**dy PC text) - which is what I meant to say!! I APOLOGISE and must check the connections between my brain and my hand!! Mind you, I've probably just confused D4L even more now LOL LOL
Sorry about the continued swearing Karl!! LOL LOL
Judder01
#13 Posted : 18 February 2013 13:43:42
I stand corrected Judder, you win, I lose Blushing - it would appear that I DID say the diameter was Pi x 2 x r didn't I, but as you correctly say, it SHOULD be 2r to get the diameter then x 3.14 to find the circomeference (bl**dy PC text) - which is what I meant to say!! I APOLOGISE and must check the connections between my brain and my hand!! Mind you, I've probably just confused D4L even more now LOL LOL
No worries, everyone makes mistakes every so often! Glad it's sorted LOL
noki49
#14 Posted : 20 February 2013 13:04:38
Well that took a few post to confirm the circumference is Pi x diameter.
The diameter of the tyre (and the rim, for opening circumference)should be able to be measured fairly accurately with a ruler.
Im still baffled as to what purpose the OP would put these measurements to.
Maybe he wants to make his own tyres or rims.
I just thought someone with the ability and equipment to do either would not have a problem obtaining these measurements themselves.
Come on D4L, enlighten us please..
#15 Posted : 20 February 2013 14:10:45
could it be that,he is a wind up geezer,nahhhhh not that intelligent.Confused
#16 Posted : 22 February 2013 20:07:30
Totally off-topic here, but all the above reminds me of a post I read 'explaining' the leap year -
Apparently it's ALL wrong, as our 24 hour clock isn't actually accurate enough to measure a solar year properly.
We are still a bit 'out' even after adding the extra day every 4 years, so infact, after 38 years, we're a 1/4 of a day wrong again......
SO..... Every 100 years, (It ought to be 128 years but astronomers some time ago decided to round it down to 100) we actually leave OUT the leap year!
BUT...... To confuse things further, because the 100 year round-down is around 28 years out, every 400 years, they put the leap year back IN, which is why the year 2000 WAS a leap year - 1900 WASN'T, and 2100, 2200 and 2300 won't be either....
HOWEVER...... Even that isn't correct enough....
Every 400 years or so (but not the 'same' 400 years!) they have decided we will need a DOUBLE leap year, hence there is a Feb 30th every 400 years....... The last one was in 1712 - The next one is between 2096 and 2116 - astronomers haven't decided yet.
BUT.... That will make us 'wrong' the other way round by a few minutes as we ought to only be removing around 23hours 57 minutes, SO, we're back to square one again, with a day being too short.
Don't give up yet - none of this fixes things entirely either as the earth is getting closer to the Sun every year and eventually a year will need to have a day removed completely.........And it will still be a few minutes adrift.
Not only that, a solar year is slightly LONGER at the South pole than the North due to the axial tilt, but in about 20,000 years time, it will be the other way round as the Earth completes its 'wobble'.
All because we didn't measure a day accurately enough long ago......
Just thought you might be interested.....
Roy.
Dontshootme
#17 Posted : 22 February 2013 21:32:07
Roy.
Blink Blink Blink Blink Blink LOL LOL
This page was generated in 0.231 seconds.
