25 Pages «<678910>»
Claret's SOTS Build Diary Options
claret
#141 Posted : 20 February 2013 13:16:52
Hi Karl,
Thanks, definetly taking my time and dry fitting several times before commiting to the PVA glue!!
Claret
Also working on:
SOTS.
Waiting in the wings:
finished:
007 Iconic DB5.
claret
#142 Posted : 20 February 2013 13:18:06
Hi Mike,
Thanks for looking in and the words of support.
I am actually enjoying this part of the model.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
claret
#143 Posted : 20 February 2013 13:19:12
Hi Alan,
Thanks.
Great fun, but a long way to go.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
claret
#144 Posted : 20 February 2013 13:21:16
Hi Dominic,
Thanks.
The flash I think was brought more of the pattern out than normally shows.
I think the couch will be appearing in many more shots in the future, it is a nice soft resting place for the camera shootsLOL
Also working on:
SOTS.
finished:
007 Iconic DB5.
claret
#145 Posted : 27 February 2013 14:13:56
Hi All,
Just an update on the planking, slow progress, as trying not to rush.
The pics speak for themselves. One or two areas not even, not sanding and filler should sort that out.
I have lightly sanded a couple o spots and it seems to do the trick.
I will post more photos of my progess at the weekend.
Thanks for looking.
Claret.
Also working on:
SOTS.
finished:
007 Iconic DB5.
#146 Posted : 27 February 2013 21:38:45
Taking shape very nicely there Claret... well done, keep the good work going and looking forward to seeing more....Cool Cool
#147 Posted : 28 February 2013 13:27:02
Hi claret.
A very nice clean build. Look forward to seeing your progress.
Keep up the good work.
Ian Cool Cool BigGrin
claret
#148 Posted : 07 March 2013 10:59:01
H Alan & Ian,
For your kind words of encouragement.
Not much progress, other commitments taking priority at present.
Hopefully start #24 instructions this weekend.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
claret
#149 Posted : 15 March 2013 14:19:56
Hi All,
Been a busy two weeks, so not a great deal of progress.
Managed to cut and sand the infils up to issue 23BigGrin
Fiddly, with sanding a bit, not fitting, sand a bit more.
results below:
Thats all for now.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
court orchard
#150 Posted : 15 March 2013 14:29:18
That's looking goodThumpUp
claret
#151 Posted : 15 March 2013 14:38:22
Thanks andy.
Also working on:
SOTS.
finished:
007 Iconic DB5.
#152 Posted : 15 March 2013 19:25:40
Hi, you are making good progressBigGrin Kind regards Mike
#153 Posted : 15 March 2013 22:27:27
Coming along very nicely Claret, well done.... BigGrin BigGrin
Admiral Anti Spiral
#154 Posted : 17 March 2013 02:10:04
Looking good claret, almost there BigGrin If i might add because its hard to tell, but you might be needing to leave more bamboo planking at the end of the keel for the stern post, keep up the good work :)
Processing - Progressing
Previous builds: HMS Victory
#155 Posted : 17 March 2013 10:24:45
Hi Claret,
The build is looking good WTG.
Would like to pick up on the Admiral`s point in the previus post, about the length of the stern planks past the end of the keel. I have left mine a bit longer than yours ,but I can`t find any reference to there being any set length to leave past the end of the keelConfused .
As a newbie to this maybe one of our more advanced members could clarify this point.
Keep up the good work Claret.
#156 Posted : 17 March 2013 10:38:55
delboy271155 wrote:
Hi Claret,
Hi Claret, I covered the overhanging stern planks issue with MWG in my build diary... If you take a look at post no 519 onwards I think you will find it very useful..... Keep up the good work...BigGrin BigGrin
claret
#157 Posted : 22 March 2013 20:37:43
Hi Alan, AAS & Derek,
Thanks for your comments and pointing out the stern planking over hang. it does seem vague and i may have cut off more than i should have, over keen with the saw. Fingers crossedBlushing
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
claret
#158 Posted : 22 March 2013 20:44:03
Hi, I have made a little more progress with fitting the stern reinforcement, I followed gandale's method of gluing and sanding the profile, fiinding this much easier.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
claret
#159 Posted : 22 March 2013 20:50:02
Hi,
Made some progess on the launch swell. I fitted 5 thwarts instead of 4 as I had an extra oar notch.
Does not look to out of place, I hopeLOL
I used a pair of compasses to get the correct length for each thwart.
Result as shown in the photo.
That's all for now.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
#160 Posted : 22 March 2013 21:58:18
Nice work Claret and no the extra thwart doesn't look out of place.....Cool Cool Also happy to hear my methods have helped you on the stern reinforcements..BigGrin .. Keep posting, your work is looking very good indeed....
25 Pages «<678910>»
This page was generated in 0.701 seconds.
