26 Pages «<89101112>»
Ian Smith Victory Build Diary Options
#181 Posted : 18 February 2013 23:46:10
Hello Ian,
Great start with the tiling are you working your way up to the water line like a triangle.
Trev.
#182 Posted : 19 February 2013 00:24:34
Hi Trevor.
I am following the coppering plan in the HMS Victory her construction career and restoration by Alan McGowan book. The copper tiles tend to curve up into the waterline. There is not a straight line of tiles along the waterline level, there are a lot of triangular cut tiles into the waterline. Yes this does look triangular.
Hope this answers your question.
Ian.
#183 Posted : 19 February 2013 10:49:39
Hi Ian you are doing a good job of the tilingBigGrin Good stuff. Kind regards Mike
#184 Posted : 19 February 2013 12:42:46
Hi Mike.
Thank you for your comments. Much appreciated. Ian.BigGrin
#185 Posted : 23 February 2013 16:24:15
Hi guys.
Just a quick update on my tilling so far.
Nine hours work so far.
Thank you for looking Ian.
#186 Posted : 23 February 2013 22:23:53
Nice work there Ian, a long drawn out job but will be well worth it in the end... keep posting your progress...
DaDokta
#187 Posted : 23 February 2013 22:59:55
Well, i`m not looking forward to the tiling :)
Looking good so far.
Keep up the good work.
Walter
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
Mo
#188 Posted : 24 February 2013 12:24:55
Love the copper hull, If I am to do another build, I will certainly go for copper,
Look forward to seeing the finished article.
Mo ❤
Mo
karl josef
#189 Posted : 24 February 2013 15:43:33
ian,since you have a lot of work ahead of you
Best regards,
Reiner
Jesus-Belzheim
#190 Posted : 24 February 2013 17:33:07
Hi Ian
you did all this in 9 Hours?
I needed a few Weeks to get this far Blushing
Keep up the good work BigGrin
Kind regards
Peter BigGrin
HMS Victory 1:84 DeA
#191 Posted : 24 February 2013 20:40:03
Hi Alan, Walter, Mo, Reinier, and Peter.
Thank you all for your very nice comments.
Most appreciated.
Peter I had four days of off work last week. Which is why I got so much done. I would say work at your own pace and do not rush any thing. The end result is worth it.
Ian BigGrin
#192 Posted : 25 February 2013 10:15:44
Hi Ian looking the businessBigGrin Kind regards MikeCool
#193 Posted : 26 February 2013 13:37:53
Hi mike.
Thanks for your comments.
Much appreciated Ian BigGrin
#194 Posted : 10 March 2013 00:27:18
Hi guys.
A quick update to my build. 22 hours of copper tiling.
Thanks for looking. Ian
#195 Posted : 10 March 2013 10:27:38
Hi Ian.... 22 hours of work and still a long way to go eh.... coming along nicely. Don't envy you the task and I know I have the tiling to come.... thankfully a long way down the future I think.....
#196 Posted : 10 March 2013 11:20:52
Hi Ian,
Good work with the tiling keep at it,but you will find that you will need a break,Ian as you work towards the water line you will find that the tiles will tend to bow or sag in the middle this will sort it self out just keep on going.
Regards Trev.
der Gohfelder
#197 Posted : 10 March 2013 12:09:38
Hi!
Nice work, but needs a lot of time and patience Cool
Regards, Bernd
#198 Posted : 10 March 2013 16:31:35
Hi Alan, Trev, and Bernd,
Thank you for your nice comments.
Trev thanks for the info about tiles towards waterline much appreciated Ian. BigGrin
#199 Posted : 10 March 2013 19:21:13
Hi Ian,
That copper works well, looks like it could be a bit of a frustrating job, how do you find it?
I`ve only just started my Vic build and still therefore have that choice to make, but that said and done I don`t want to paint it copper and think I`d made the wrong choiceConfused .
#200 Posted : 10 March 2013 19:39:49
Hi Derek.
The tiling is a very long time consuming job.
It gives the model the finish she deserves in my view
I prefer the tiles to copper paint bottom. Glue wise I found evo stick serious glue easier on your fingers than super glue and super glue gel, doesn't leave your fingers sore when you get it off.
Hope this helps you to make your mind up.
Regards Ian.BigGrin
This page was generated in 0.212 seconds.
