Brass eyelets Options
Mo
#1 Posted : 24 February 2013 12:14:25
Can anyone help, I have run out of the small brass eyelets for my Surprise build, I did order and receive what I thought was the right thing, but the ones that came were longer and thicker than I required,
Can anyone tell me a supplier and a part number to order. The eyelets I need are .6 mm thick the overall length is 7 mm
Mo
Mo
#2 Posted : 24 February 2013 12:19:20
mo 6mm.is mighty thick do you mean the diameter if so try cmb they do eyelets all sizes.
Mo
#3 Posted : 24 February 2013 12:21:03
Thanks Karl, they are .6 mm thick, I really need a part number if I can get one, I ordered what I thought was the right thing but alas it was not.
Mo
Mo
#4 Posted : 24 February 2013 12:51:57
sorry mo really confused here,brass eyelet???? what you put in the deck and tie rigging to????? 6mm. thick that's 1/2" that's brass rod,or do you mean those thing that you use for portholes??? and are also used for holes in belts.??? pic if possible.
Mo
#5 Posted : 24 February 2013 12:56:15
Karl, the eyelets are .6 mm. That's point 6 of a mm. The one used on the deck and used on the cannon's
Mo
Mo
#6 Posted : 24 February 2013 12:57:25
okey doke,stand b ye.
#7 Posted : 24 February 2013 13:05:50
http://www.cornwallmodel...log/amati_eyebolts.html
http://www.cornwallmodel...ing_boats_eyebolts.html
http://www.cornwallmodel...a_eyebolts_eyelets.html
TRY THOSE.sorry 'bout the pic,no idea what happened there.?
Mo
#8 Posted : 24 February 2013 13:14:30
Thanks Karl, but none there are what I am looking for, the ones I bought were 10 mm long but still to thick, can you get them from DeAgostini
Mo
Mo
#9 Posted : 24 February 2013 15:05:34
why don't you make them your self,easier then you think.
willie
#10 Posted : 24 February 2013 16:07:11
try e-bay 100 gold plated eyepins 0.6mmx50mm long 99pence plus 99pence postage,200 £1.98p
This page was generated in 0.057 seconds.
