17 Pages <1234>»
court orchard
#21 Posted : 26 February 2013 22:48:12
Hi Jase,
The Porthole Eyebrows are included in the MK1 Etch along with all the Portholes, along with all the minute Grab Handles.BigGrin
#22 Posted : 27 February 2013 07:39:04
court orchard wrote:
Hi Jase,
Thanks for the info that's great news.
Have you started yours yet wold love to see you progress
#23 Posted : 27 February 2013 21:55:51
Very nice start Jase.... will be watching to see how you progress with your modifications.... been some 45 years since i built a war ship, airfix bismark, pretty basic and cheap... saved my paper round money for that one..LOL LOL ... From there I moved onto gliders and was chuffed when they actually flew... stopped modeling altogether when I reached 16... Think I have missed out on so much of this hobby through the years but at least back on it now and loving it.....BigGrin BigGrin
court orchard
#24 Posted : 27 February 2013 23:58:38
Hi Jase,
Hi Jase,
I've done some work on the Hull and added the main pieces, but that's it. The Hull is very thick and can take a lot of sanding, The Bow nose pieces didn't fit that well and needed quite a bit of work. I've been considering the PE for the vents, but I think that the moulding is OK and they will look too obvious with PE. I'm a bit fazed by all the tiny MK1 PE and the Hull painting (ie Boot Top) so I'm kinda waiting for you to lead the way
#25 Posted : 28 February 2013 00:28:11
Hi Jase,
Hi Jase,
I agree the hull vents are fine, I will try and do my best to explain all the techniques i use as i go along but you can always ask anything as we go. Boot top will be a challenge as it is not marked. i have a 1:350 tamiya kit though so plant to take measurements and scale up. I think after the hull should be relatively straight forward construction - famous last words.LOL
Are you going to put a build diary up? it would be good if we could get 2 or three going.
Going to model boat show Sunday see if i can get a nice standBigGrin
court orchard
#26 Posted : 28 February 2013 11:39:21
Thanks JaseThumpUp
I might do a Build Diary, but I'm a bit of a novice when it comes to plastic Battleships.
I notice that there's a problem with the Boot Topping/Waterline level at the Stern. If you mark it at a constant level from the Base it looks too low and needs correcting upwards.
I saw that you were asking about Smoke Generator Canister Hatches on the MK1 Decking, they are there as you can see on the Photo, but no Crew Access Hatch to the Smoke Room as on the Artwox Deck.
#27 Posted : 28 February 2013 12:41:09
[quote=court orchard]Thanks JaseThumpUp
Thanks for the deck pic Andy Deck looks ok, I will wait and see for my self befor i decide if I am shelling out for another deck.
I would not worry just go for it on the build diary front you will probably inspire more people to have ago and get more help ant tips from the forum that way. BigGrin
Interesting comment on the boot topping. The shape of the bow dictates that the line plunges under the bow also the depth of the line increses. I will post a pic of my 1/350 bis tonight to give you some guidance.
J
#28 Posted : 28 February 2013 21:00:21
Answer to boot toping question...
The top line should be 47.5mm from the keel at the centre of the ship. Your quite right if you follow that line you will drop at both the stern and bow, 5mm at the bow 3mm at the stern. 47.5 gives you 32.5 from Boot top to deck if you follow that line you should correct the line. the boot to p should be 10mm deep (although i have been toying with doing mine 8mm for aesthetics, but probably wont LOL ). Hope that helps
Wilfy the Sea Dog
#29 Posted : 28 February 2013 23:33:28
Hi Jase,
I am going to try & start my Bismarck in the next couple of weeks, looking at your posts so far, you are much more knowledgeable than I am about battleships.
I don't understand the 'boot topping question' could you explain it in 'idiots' terms please. BigGrin
Thanks
Wilfy
#30 Posted : 28 February 2013 23:54:38
BigGrin I think this is right but not completely sure, The boot topping is a measure of draft that indicates to the crew its weight or where the red anti fowling paint meets the grey paint of the upper hull. So if a ship is riding high or light the red paint line can be seen, the more weight on the ship then it becomes lower in the water so a ship that is riding exactly to the boot topping line is at its optimum weight with a full crew and stores on board. Different ships have this line set at the design stage, thus a container ships can have a higher boot topping compared to a warship
#31 Posted : 01 March 2013 00:02:17
Thats pretty much it. BigGrin all you need to know from a model point of view is that we are talking about the black line that divides the grey and antifouling red of the lower hull and runs the full length of the hull. On Bismarck the Boot Top was 2 meter deep on her sister ship Tirpitz it was slightly deeper.
#32 Posted : 01 March 2013 00:07:45
Wilfy the Sea Dog wrote:
Hi Jase,
Thanks
Wilfy
Great Wilfy i am probably a couple of weeks from getting properly stuck in also - I just need to get Hood of my desk Cool and finally receive my upgrade kit.
Looks like we could have 3 Bismarck BuildsLove which will be fantastic as they will all come out different I am going to do my Bismarck with yellow turret tops, just to be controversial Blink
J
Wilfy the Sea Dog
#33 Posted : 01 March 2013 00:14:38
Thanks for info, think I understand the principle.
So the 'boot topping line' is the demarcation line between the red paint & the grey paint on the model. This is 47.5mm from the keel at centre, 42.5 mm at the bow & 44.5mm at the stern. So if I was to draw a line mating up these points I would have have the position to mask & paint the lower hull?
Thanks
Wilfy
#34 Posted : 01 March 2013 00:21:02
Thanks
Wilfy
Yes that would give you the top line the bottom line should 10mm bellow. Don't fall into the trap that some Bismarck model builders do and paint the false bow and stern black it should be very dark grey
J
Wilfy the Sea Dog
#35 Posted : 01 March 2013 00:23:21
J[/quote]
I was going to start an aircraft kit next, but think it would be great if the three of use could work through the Bismarck together, I will have to take advice from yourself & Court Orchard as my knowledge of her is not great.
Need to purchase some referance material I think.
I have all the components here now, I bought the Lifecolour paint sets as I prefer acrylics, so I have no excuse apart from space to get going.
Wilfy
#36 Posted : 01 March 2013 00:34:32
Wilfy[/quote]
There is quite a lot, and growing, reference material in the links on the first post of this build diary. i will be adding pic references as i go. try this for some stunning build reference material http://3dhistory.de/wordpress/?page_id=179
I agree three builds progressing together will be great, and hopefully we will all come out of this with something special. Cool
J
Wilfy the Sea Dog
#37 Posted : 01 March 2013 00:39:16
Thanks for the link jase, will be very useful.
I just did a search on the 'anotomy of a ship' series of books looking for Bismarck & sellers on Amazon wanted £500! What!
Wilfy
#38 Posted : 01 March 2013 00:51:56
J
Wilfy[/quote]
Talking of space, its looking like Trumpeter are lining up the release of a 1/200 USS Hornet aircraft carrier, which will be a serious space eater.. Blink
https://www.facebook.com...mp;type=1&permPage=1
#39 Posted : 01 March 2013 00:57:45
https://www.facebook.com...p;type=1&permPage=1[/quote]
wow that will be some serous kit Cool
#40 Posted : 01 March 2013 00:59:04
Wilfy
flipin eck - is embossed gold leaf!!!
Guest (10)
17 Pages <1234>»
This page was generated in 0.451 seconds.
