3 Pages 123>
A new start by Delboy Options
#1 Posted : 02 March 2013 22:54:49
Hi all,BigGrin
This is a very late starter, I`m new to this kind of modelling but have gone for it 100% as I am also building the SOTS.
My Victory build will be in the Trafalgar colours with copper tiled hull,paints supplied by CMB as a set, purely because they do single pots in each colour if you need a top-up.
I start with the 12lb cannon,wood primed with Humbrol matt white(already in my stock)and barrel lightly sanded and painted.Pic 1
Having verified the correction of the cannon carriage assembly,I continued to assemble the whole 12 pounder. Would be interested in how to improve the wheels with retainer pins showing etc,but this is the state of play at the moment.Pic 2
Sorry about the focus on that one, like my old school report "can do better, must try harder"LOL LOL LOL .
After the cannon I turned my attention to the forward frame work, Just the first couple of parts at the moment.Pic 3
I then turned to the anchor, I still have to attach the bindings to the stock and fix the rope but this is as it is at the moment.Pic 4
I`ve found I learn in two ways:
1: Ask questions
2: Listen to feedback
So to that end feel free to come back to me, be it good or bad.
Waiting for next parts, so will update asapBigGrin
#2 Posted : 02 March 2013 23:01:38
So Derek, you have made a start on your victory and a nice start it is too... Am very tempted to start my Vic, sort of biting my tongue, shackling my hands and storing issues out of sight..... the itch is growing but so far able to resist the temptation... for how much longer who knows... Glare .. Good luck on your latest venture....
#3 Posted : 02 March 2013 23:20:08
Hi Alan,
Started mine due to initial delivery problems with Sots, those issues seem to have settled at about 6-7 weeks behind, which is not such a bad thing, I get to see what`s going on before I try it. Also means if the planking starts to get a bit heady I can go to some of the basics with the Vic.
Happy Building
#4 Posted : 02 March 2013 23:25:26
Derek, have sent you PM...
#5 Posted : 02 March 2013 23:28:33
Hi Delboy.
Nice start as Alan said! I wish I'd known about the wrong-way-round cannon carriage too! I only bought the issue 1 to see what it was like and I'm going to eventually use the 12lb in a mini diorama and yes, I built it the wrong way too! Still never mind, stick enough crew around her and she should still look good! BigGrin
The easiest way to add the retaining pins to your trucks would be to forget about actually getting them through the axles and simply make either a sliver of wood or file a bit of brass wire to the tapered shape and then cut off the top and bottom pieces and glue them directly to the trucks above and below the axle position. I might try that myself on the diorama too.
Happy building D.
#6 Posted : 02 March 2013 23:32:48
Plymouth57 wrote:
Hi Delboy.
Happy building D.
Cheers Robin
Will give that a go thanks
#7 Posted : 03 March 2013 01:01:10
BigGrin Hi Delboy
good luck with the build and I think someone used cocktail sticks as axles for the guns
Jesus-Belzheim
#8 Posted : 04 March 2013 15:54:26
Nice start Derek BigGrin
Kind regards
Peter BigGrin
HMS Victory 1:84 DeA
#9 Posted : 04 March 2013 16:04:17
Hi Derek.
Nice start. Keep the good work.
Ian BigGrin
#10 Posted : 04 March 2013 19:28:59
Thankyou all,
DaDokta
#11 Posted : 04 March 2013 22:57:41
Hi Derek,
i don`t know if it`s the angle of the picture, but to me it seems that the stock of your anchor is turned upside down. The straight side should face away from the anchor (i´m sorry for my english!) whereas the curved side should face downwards.
Keep up the good work,
Walter
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
#12 Posted : 05 March 2013 19:43:16
DaDokta wrote:
Hi Derek,
Walter
Walter,
I`d like to say you spotted the deliberate mistake,LOL ,but no such luck, I dropped a clanger. well it`s back to the start with that one.
Many thanks for pointing that out now as I still have not done the bindings on the stock, so may be easier to part.
#13 Posted : 05 March 2013 21:48:08
Good News,
Careful knife line along the joint, plastic beaker of boiling water and hey presto with the aid of a small chisel the two halves of the stock separated Cool.
Just a little Blushing, but hey sorted without too much hassle.
Thanks again Walter BigGrin
#14 Posted : 06 March 2013 08:50:37
Good recovery there, Derek. Never fear we all make mistakes, just makes us stronger and better. You will note my footnote as a reminder. Keep up the good work and the pics coming.
willz
#15 Posted : 06 March 2013 15:31:59
Active Service Medal: 500 post active service MedalTurquoise Medal: Turquoise Medal for model making know-how contributionOutstanding Build: An award for an outstanding buildBuild-Diary Medal: Build-Diary Medal of Honour
delboy271155 wrote:
DaDokta wrote:
Hi Derek,
Walter
Walter,
no need to part the stock just take out the ring and twirl it round
#16 Posted : 06 March 2013 19:17:06
Willz,
Thanks for the idea but I had managed to cut the slot in the stock so close it wouldn`t come off, so I resorted to the Cursing let`s get the glue softenedCursing methodCrying .
Which i am glad to say worked without any damage to the parts.
BigGrin Cool BigGrinCool BigGrin Cool .
#17 Posted : 06 March 2013 22:03:15
delboy271155 wrote:
Willz,
Well done Derek.... another lesson learnt and never to be repeated....Blushing Blushing ... lots of lessons still to come no doubt....
#18 Posted : 06 March 2013 22:19:05
delboy271155 wrote:
Willz,
Hi Alan,
You hit the nail on the head there mate. Yep, it seems read, look, read again then do should include look at the darn pictures too, not just the parts. Blushing Crying Blushing
#19 Posted : 08 March 2013 14:50:04
Hi Derek.
Looking good. Guess who also made the same mistake.
Glad you where able to sort it.
That's how we learn. Ian.BigGrin
#20 Posted : 08 March 2013 15:00:26
ian smith wrote:
Hi Derek.
Hi Ian,
Thanks for looking in,hope you have the same luck correcting yours.
3 Pages 123>
This page was generated in 1.538 seconds.
