help with warped parts Options
ronnie read
#1 Posted : 19 May 2010 20:14:37
Rank: Amateur Level 1
helloLOL Confused LOL
when it come to warped parts do i use hot warm or cold water before clamping i have been lucky so far as only 13 is warpedCursing any and all advice welcome
snowtiger
#2 Posted : 19 May 2010 20:32:27
Hi Ronnie ....well i dont soak them ....i use a damp tea-towel and a very hot steam iron....with the bits being ply-wood i find the direct heat softens the glue a little and then hardens a lot faster than the wood being soaked...the damp tea-towel is there just to stop the wood from burning .BigGrin ...and beggaring up the wifes new steam iron....LOL ...hope this helps mate...BigGrin BigGrin
ronnie read
#3 Posted : 19 May 2010 20:37:38
thanks snowtiger
will give a go after ironin do i still need to clamp it between two flat surfaces
snowtiger
#4 Posted : 19 May 2010 20:42:24
Hi ronnie .....nope it does not need to be clamped....just check it after half an hour ..(make sure the wood has cooled off)if some warping is still there ....then repeat on the warped area....it may take several passes ....but you will get there ...BigGrin
john...
ronnie read
#5 Posted : 20 May 2010 11:15:49
hi snowtiger
thanks for the advice very helpful
James
#6 Posted : 20 May 2010 13:09:48
I have a few warped parts too, I will also try the ironong method and see how it works.
Now comes the hard part, does anyone know how to operate an iron
James
Dontshootme
#7 Posted : 20 May 2010 14:59:54
James
Yes ...plug the wife in to the wall socket using a funny wedge shaped thing with a lead & plug attached!!
James
#8 Posted : 21 May 2010 06:14:58
Tried to plug wife in, I now have a funny wedge shaped bruise right in middle of my forehead.
Laugh
James
Dontshootme
#9 Posted : 21 May 2010 09:55:41
LOL....did you try sneaking up on her?Sometimes that works..especially if she is doing the ironing at the time.
#10 Posted : 21 May 2010 10:23:05
I get my wife to sit on the warped parts, does'nt fix it but we have fun trying.
willie
#11 Posted : 21 May 2010 11:02:31
try proping parts up on two books or some thing, puts weight on it so its bends the other way about the same distance leave for a day checking now and again
Mac
#12 Posted : 21 May 2010 13:17:26
Karl you are so bad!LOL
Pam's shipyard is closed for now no more room!
Dontshootme
#13 Posted : 21 May 2010 19:35:17
If I did that I would first of all get a slap in the face & then get told to get my own dinner...luckily for me my son is a chef!!
Jack Sparrow
#14 Posted : 21 May 2010 20:09:57
Tried that.......now where did the launch go?!?!?!?!?!LOL LOL LOL
This page was generated in 0.281 seconds.
