Permagrit sanding blocks Options
Captain David
#1 Posted : 12 March 2013 19:21:38
Has anyone tried these?
Not cheap but you would never buy sandpaper again!
I saw them on my local Hobbystore website.
http://www.permagrit.com/index.php?cPath=65
http://www.permagrit.com/index.php?cPath=74
#2 Posted : 12 March 2013 20:51:52
Hi Cap'n David
I've got a Sandvik sanding block which is very similar and it's still going strong after more than ten years!
They will last far longer than sandpaper but you will still need the good old fashioned stuff especially for complex curves on the hull after first and second planking and also for wrapping round the mast dowels too. The 'plate' types are great for flat sanding but they can't bend round things like sheets can.
I find the most useful sanding implement for large areas is the foam block, comes in various grades and very cheap if you find a good shop (I get mine from "The Toolbox" shop in Plymouth but they're widely available. Cool
Good Luck building!
#3 Posted : 12 March 2013 21:43:50
Permagrit also do flexible sanding sheets, which are thin enough to be bent to any shape, internal or external..
http://www.permagrit.com...rksutts2he8kb426bpgtf1h7
#4 Posted : 12 March 2013 22:19:03
Oh! nice one Mr T, never knew they had that! Cool
This page was generated in 1.054 seconds.
