Joined: 27/02/2013 Posts: 228 Points: 664 Location: Bursledon
Has anyone tried these? Not cheap but you would never buy sandpaper again! I saw them on my local Hobbystore website. http://www.permagrit.com/index.php?cPath=65
http://www.permagrit.com/index.php?cPath=74
Hi Cap'n David I've got a Sandvik sanding block which is very similar and it's still going strong after more than ten years! They will last far longer than sandpaper but you will still need the good old fashioned stuff especially for complex curves on the hull after first and second planking and also for wrapping round the mast dowels too. The 'plate' types are great for flat sanding but they can't bend round things like sheets can. I find the most useful sanding implement for large areas is the foam block, comes in various grades and very cheap if you find a good shop (I get mine from "The Toolbox" shop in Plymouth but they're widely available. Good Luck building! Robin First wooden ship: The Grimsby 12 Gun 'Frigate' by Constructo Second: Bounty DelPrado Part Works Third: HMS Victory DelPrado Part Works 1/100 scale Diorama of the Battle of the Brandywine from the American Revolutionary War Diorama of the Battle of New Falkland (unfinished sci-fi), Great War Centenary Diorama of the Messines Ridge Assault Index for the Victory diary is on page 1
Permagrit also do flexible sanding sheets, which are thin enough to be bent to any shape, internal or external..http://www.permagrit.com...rksutts2he8kb426bpgtf1h7
Oh! nice one Mr T, never knew they had that! Robin First wooden ship: The Grimsby 12 Gun 'Frigate' by Constructo Second: Bounty DelPrado Part Works Third: HMS Victory DelPrado Part Works 1/100 scale Diorama of the Battle of the Brandywine from the American Revolutionary War Diorama of the Battle of New Falkland (unfinished sci-fi), Great War Centenary Diorama of the Messines Ridge Assault Index for the Victory diary is on page 1
