Stuck on frame 7 & 8 Options
riff-raff
#1 Posted : 16 March 2013 21:30:10
Hi group
I have just started this build and received the first 4 packs of parts.
I have started to build the frame work as described in the instructions and have come across a problem. Frames 7 and 8 (which are identical) both have locating pegs at the bottom of the frames, however, the base to which 4 frame parts attach only has 3 sets of holes.
Should I remove the location pins from frame 8 or drill location holes in the base to accommodate the pegs?
thanks guys
Riff-Raff
Built:
#2 Posted : 16 March 2013 21:37:29
BigGrin Hi Riff Raff
the two parts with lugs are part 8 the missing part without lugs is sent later I think in the next pack of 4 if you chop off the lugs and use it then it can affect the hull shape later on. hope this helps
Ps This problem with the hull formers has been mentioned in several build diary's and it was the same in Japan when it was 1st issued there
dbartonjr
#3 Posted : 03 April 2013 09:48:32
Hi there,
I ran into the same problem and you must wait for the proper part. I decided to cut off the lugs only to find that I had to deconstruct the hull because it was misshaped. Patience will save you a lot of time.
Dan
Current Builds: Yamato
On the Bench: Akagi, USS Missouri
Taz
#4 Posted : 10 June 2013 07:00:34
Hi
It looks like that the problem with two No.8 frames has not gone away.I have just received my first issue and have the same and will have to be patient and hope No.7 arrives in the next delivery.
Taz.
Taz
#5 Posted : 05 July 2013 07:31:43
Hi all
Just to confirm that you do get replacement ribs in issue 02,I just received mine yesterday.BigGrin
Taz.
This page was generated in 0.104 seconds.
