galley Options
cal
#1 Posted : 18 March 2013 20:19:34
hi guys m in need of help after putting the poop deck the back end loks to reallyo ut of shap the ship as a whole looks to be straight but theres about 5mm differance from one side of the galley to the other the pics ive added are after i took off the panel (60) any suggestions what i can do to fix this problem
thnaks cal
cal attached the following image(s):
#2 Posted : 18 March 2013 21:57:10
I'm affraid it looks like you will have to remove the gallery and remeasure the gallery location on the starboard sid e and even it up,I suggest you soak the gallery in warm water for ten minuets then carefully remove the gallery.allow 24 hours drying time,then redo after measuring.good luck. k.
Skipper
#3 Posted : 20 March 2013 20:31:18
Rank: Amateur Level 1
...and parts will shrink in the drying process after soaking in water. I had a little surprise but observed natural process and corrected position as required to get a good fit. As I measured position I had to learn that planking on both sides is a little bit different - only a mm but trusted my eyes to find correct position. So, no easy task but with a second attempt you will succeed. best luck & keep up good work, Stefan RollEyes
cal
#4 Posted : 21 March 2013 16:30:36
thanks guys here goes nothing lol
This page was generated in 0.091 seconds.
