Bow planks issue 24/25 Options
#1 Posted : 20 March 2013 20:17:58
Hi AllBigGrin ,
Have what may be a minor problem(I hope),by the end of issue 24`s planking my lower and upper planks will meet at the bow, but in the mag instructions there is still a gap after the planking of issue 25.
I can only assume that I have not tapered the planks enough,so is this a case of removing planks and thinning then refitting, or, as this is only the base planking does it not matter?
Ideas/comments welcome,
benny b
#2 Posted : 20 March 2013 20:58:18
hi delboy i had the same problem but just kept going have finished hull now and it looks right same as you said i dont think it maters on first layer
#3 Posted : 20 March 2013 21:10:16
BigGrin Hi Derek don't worry carry on planking it will work out ok as long as it is smooth . It will need filling anywayCool
#4 Posted : 20 March 2013 22:01:45
Cheers GuysBigGrin
Thought that was the case, just wanted to checkCool.
#5 Posted : 20 March 2013 22:17:29
Cheers GuysBigGrin
Hi Derek, my build went the same way but if you have a look at my posts you will see how I just carried on to complete the first layer.... As long as it's covered and smooth then it won't be a problem after filling and sanding... Do need a good finish though before starting to apply the 2nd layer.... Good luck....
This page was generated in 0.156 seconds.
