25 Pages «<7891011>»
Claret's SOTS Build Diary Options
#161 Posted : 22 March 2013 22:12:19
Hi Claret, a really nice job BigGrin Good stuff Kind regards Mike
der Gohfelder
#162 Posted : 22 March 2013 22:57:28
Hi Claret!
Well done, a very nice work! Keep on this way! BigGrin
Regards, Bernd
claret
#163 Posted : 24 March 2013 13:29:42
Hi Alan, AAS. & Derek,
Thanks for your encouraging comments.
Looking a the Italian build, it looks like we sand down the bamboo planks to 2mm from the back of the false keel. Mi think I will be okay with what I have done.
Thanks again for pointing me in the right direction.
Claret
Also working on:
SOTS.
Waiting in the wings:
finished:
007 Iconic DB5.
claret
#164 Posted : 22 April 2013 22:29:32
Hi,
I have been busy doing the model, but not had a chance to update the diary.
Progressed on the launch, pic below.
Also been progessing with the planking as shown.
More to follow.
claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
#165 Posted : 22 April 2013 22:37:52
Looking good Claret, well done.... BigGrin
claret
#166 Posted : 22 April 2013 23:42:52
Hi Alan,,
Thanks for looking in and commenting
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
#167 Posted : 23 April 2013 10:02:00
Good clean job you have there, Claret, well done. She sure has some beautiful lines. Keep it up.
claret
#168 Posted : 23 April 2013 12:09:46
Hi Hans,
Thanks for the kind comments.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
claret
#169 Posted : 23 April 2013 13:52:20
Hi,
I have a back log of photo's showing the bottom half of the hull being finished.
Planking is a little ropey in places, but I am hoping sand paper and elbow grease will sort it out.
Here is my progress..
Claret.
Also working on:
SOTS.
finished:
007 Iconic DB5.
claret
#170 Posted : 23 April 2013 13:59:05
Hi,
And continuing on from the last post, I have ensured I have used copious amounts of glue along all the plank edges and on the rib forms.
A view of the bow..
Almost complete!
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
claret
#171 Posted : 23 April 2013 14:14:47
Hi,
I glued the back parts, which fitted very well, added the dummy gun supports, using pins from behind, plenty of glue and a few off cuts to add more support.
Then started to plank upwards.
Thats all for now. Thanks for looking in.
Claret.
Also working on:
SOTS.
finished:
007 Iconic DB5.
#172 Posted : 23 April 2013 19:26:40
WTG Claret,BigGrin
That`s looking good M8.Cool
#173 Posted : 23 April 2013 22:42:50
Very nice work Claret, looks as if she will sand down very nicely.... Good job... BigGrin BigGrin
claret
#174 Posted : 28 April 2013 11:33:02
H Alan,
Slow progress at present, fitting last rows of planks with no ribs to clamp or pin to. Gluing one row, clamping them and allowing the glue to cure for 24 hours.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
der Gohfelder
#175 Posted : 28 April 2013 11:48:11
Hi Claret!
A really nice and clean work, well done!
Do you only glue the planks on the ribs or do you also glue them to each other? I always also glue them at the thin side of the wooden strip to each other because with this I get better results and don´t have to sand very much. Also preparing the gunports is easier.
Regards, Bernd
#176 Posted : 28 April 2013 13:12:10
BigGrin Nice Build ClaretBigGrin Rgd martyn
#177 Posted : 28 April 2013 13:41:59
Hi Claret, a nice clean buildBigGrin Kind regards Mike
claret
#178 Posted : 29 April 2013 09:23:40
Thanks Mike.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
claret
#179 Posted : 29 April 2013 09:25:38
Hi Bernd,
Thanks for your kind comment.
I glue the planks to the ribs and to each other along the length, using copious amounts of glue.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
claret
#180 Posted : 29 April 2013 09:27:03
Hi Martyn,
Thanks for looking in and posting the encouraging comment.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
This page was generated in 0.340 seconds.
