Hit a snag Options
RobT
#1 Posted : 22 March 2013 23:14:03
I have a feeling i'm gonna have to do some rescue work here Angry
I spent ages fairing the hull and thought it looked fine. However, the first 3 planks went on great, but the 4th has a distinct step in from the 3rd one around the curve of the bulkhead. Does it sound like I've made the cardinal sin of taking too much off the bow former?
If so, can it be rescued?
#2 Posted : 22 March 2013 23:18:07
Hi Rob, if you want fellow builders to give you the best advice possible then a few pics of the problem would go a long way to identifying the issue and assessing the best way forward.... Hope you can post some pics for us to see.....
RobT
#3 Posted : 22 March 2013 23:26:20
Actually, i think i'm going to have to just lift the planking and start again. Close up pics look absolutely awful. So bad that I would be embarrassed to show them on here. I think my eyesight is struggling tbh. I'm not noticing things with normal vision. It has shown that some of the bamboo on the other planks is slightly split despite pre drilling with a 0.5 bit.
Tough lesson, but you live and learn. Now to try and get the planks off without causing too much damage.
What I need to know is whether the planks have to feel baby bottom smooth from top to bottom or whether everyone has some undulations that need sanding or filling?
#4 Posted : 23 March 2013 00:02:42
Rob, if you look at my build diary I think you will see all you need to successfully plank your ship.... have a look, you have nothing to lose and lots to gain.....
RobT
#5 Posted : 23 March 2013 00:17:23
Yes, i'm half thinking about just fitting balsa in the bow. That is without doubt the most problematic part, so a balsa fill might well help me. Then if I have taken too much off, I maybe able to fill in between the balsa. It will be more difficult though as the bulkhead is in situ.
#6 Posted : 24 March 2013 19:03:01
Blink If its not to bad .You can use filler and sand down to a smooth finish.Regard's MartynBigGrin
RobT
#7 Posted : 24 March 2013 23:49:27
Thanks. I removed the planks and fitted balsa between the bow formers. It has replanked quite well. There are some minor undulations, but definitely nothing that a good sand and fill session wont fix.
How many planks on average do you guys manage to fit each building session. I'm finding i'm doing a row each side and needing a break.
#8 Posted : 24 March 2013 23:54:58
Hi Rob, happy to see it is now working out for you... personally in an evening I may get around 1 or 2 rows done, not much more than that... Also, I like to ensure the PVA has set before moving onto the next plank so that slows things down too...... Hope this answers your question///
#9 Posted : 25 March 2013 00:41:42
I used to do two to three rows a night but that slowed down when adding steelers. if you are painting rather than staining you can always use filler or even some additional planking on top sanded down to smooth out the hull shape. it worked for me. also how are you bending the planks? one i moved away from using the scissors type plank bender to a soldering iron it improved my planking no end.
J
RobT
#10 Posted : 25 March 2013 00:50:07
I'm using the amati plank bender. Working fine for me. A bit hard work on the hands though.
Mike Smith
#11 Posted : 25 March 2013 17:06:31
Rank: Beginner Level 3
Hi Rob, there is an easier way, slightly more lengthy, but the planks that require a significant bend around the hull I soaked first for a couple of hours. Then using a t-light in a tin can I slowly bent the timber around the outside of the tin can. It works very well and because the wood is wet, it does not split and when it will dry to the shape. It is a technique that I have used before, but on a bigger scale for bending the handle in a walking stick........wood is wood and flexible if handled sensitively.
Mike
This page was generated in 0.411 seconds.
