7 Pages «<4567>
Dragon Morser 'Loki' Gerat build Options
#101 Posted : 24 March 2013 22:55:39
Awesome job, wanna build mine now!!!BigGrin BigGrin
#102 Posted : 24 March 2013 23:36:41
BigGrin Hi Nem
all I can say is thanksBlushing
#103 Posted : 24 March 2013 23:39:49
The railings have now been fitted, some transfers to add then some weathering and the crew to make a mess off LOL
#104 Posted : 25 March 2013 13:33:32
Lovely job there Andy. Watching with interest.
SennaMentalMe
#105 Posted : 25 March 2013 17:09:20
Great job as usual Andy, another fine looking model from the 'arpurchase' stable!! Cool ThumpUp
Well done and keep up the good work my friend!!
Dontshootme
#106 Posted : 25 March 2013 19:05:51
Looking good there Andy.Hope you don't mind me asking this question it is not a critisim although may appear to be to anyone not reading it properly.
Looking at the photo which shows the barrel end on,if you had to do it again would you have decided to paint the inside of the barrel so that the base plastic colour doesn;t show or would you have still left it au naturel?
#107 Posted : 25 March 2013 21:34:59
BigGrin Hi Hans, SMM and Rob
Thanks for the comments and she has turned out a lot better than I hoped, I have ordered the shell transport tank from Trumpeter apparently there were 2 or 3 per morser to keep it firing but I will be using only 1 for my 1st dio.
Rob your comment is perfectly ok and in hindsite I probably should have painted the inner gun barrel but in normal light and at normal angles it cant be seen unless you pick it up and stare down the barrel, the etch insert is about 2 inches deep and its the flash on the camera that lights up the inner barrel and makes it stand out like saw thumb so to speak. Again thanks for looking and your comments
#108 Posted : 29 March 2013 17:14:10
Muds been out again, I have tried to diminish it as it goes up the hull and put it where most foot traffic would be, not sure if it worked but im happy with it. The transfer's have also been applied also.
The last two pic's show the Trumpeter loading tank that I will be building soon and its size compared to Loki also the two turned ali shell's are shown too that are included in the kit.
As always all comments/questions are welcome
moriarty
#109 Posted : 30 March 2013 14:05:01
Turning out really good. The loader will make up a really dioCool
HMS Surprise
HMS Snake
HMS Bounty
HMS Royal Caroline
HMS Victory rebuild
HMS Supply
#110 Posted : 30 March 2013 17:11:31
BigGrin Hi Moriarty
Thanks for looking in and yes the loader will certainly give a better perspective
#111 Posted : 11 April 2013 12:43:09
I needed more figures so I could have the morser and supply tank crewed properly for the dio, so after a little searching came across these, says it's for 'Karl but what the heck any crews a crew on a gun. Also there are some nice extra's in the way of equipment.
I wont be using them all but it gives me some practice pieces to play with aswell
#112 Posted : 11 April 2013 13:13:59
looks like a nice set - and as usual the men in charge are stood about doing nothing LOL LOL
#113 Posted : 11 April 2013 14:26:23
BigGrin Things never change do theyCool
#114 Posted : 11 April 2013 14:35:49
Nice work Andy ThumpUp
#115 Posted : 11 April 2013 16:51:26
BigGrin Hi Tom
Thank you
#116 Posted : 11 April 2013 16:53:23
Made up 2 of the crew provided in the 'Loki' kit just to see how they turned out here they are with a coat of grey primer and yh its still wet
#117 Posted : 11 April 2013 19:05:12
Really looking forward to seeing the completed dio!! Stunning work so far and I am sure that the finish of all the pieces will be just as awesome!! Fantastic work sir, and looking forward to your next installment!!BigGrin BigGrin BigGrin BigGrin BigGrin BigGrin
#118 Posted : 11 April 2013 19:20:49
BigGrin Hi Nem
#119 Posted : 13 April 2013 18:22:02
This is the version I got to go with mine.BigGrin
#120 Posted : 13 April 2013 19:45:23
BigGrin Hi Nem
Lots of people doing the il stand around a give advice routine on there
7 Pages «<4567>
This page was generated in 0.425 seconds.
