2 Pages 12>
SkyFire's Victory Options
skyfire
#1 Posted : 28 March 2013 02:15:00
First photo of lots. Opened the section with the wood in it, to check the fit of the parts, which was very good.
skyfire
#2 Posted : 28 March 2013 02:16:01
The Victory's 12lb cannon. Needs some yellow ocher paint on on it, this can wait until I'm actually building the Victory.
skyfire
#3 Posted : 28 March 2013 02:16:36
Anchor for the HMS Victory, sitting on the HMB Endeavour.
skyfire
#4 Posted : 28 March 2013 02:17:12
A bit more work on the Victory. The paints in the back right corner are admiralty paints for the Endeavour.
skyfire
#5 Posted : 28 March 2013 02:17:49
Latest bit of work on the Victory.
skyfire
#6 Posted : 28 March 2013 02:18:29
Added the bulkheads to the keel, to see how things look. Not glued them in yet, I want the complete deck before I do. The keel wasn't totally straight when I bought it.
skyfire
#7 Posted : 28 March 2013 02:19:13
Ships boat for the Victory.
skyfire
#8 Posted : 28 March 2013 02:19:57
Balsa added to the bow.
More work on the ships boat
Overview of the build so far. The frames are not glued in yet.
The mast is actually the foremast for the Endeavour, it just happens to be the right diameter.
skyfire
#9 Posted : 28 March 2013 02:20:41
Not too long to go before I get the deck, things will look a lot better once the deck is in place. The balsa will be used to help keep the bulkheads square.
skyfire
#10 Posted : 28 March 2013 02:21:44
HMS Victory as she is now, with the start of the HMS Hood off to one side.
skyfire
#11 Posted : 28 March 2013 02:22:21
Latest update on the Hull.
The bow frame, dosen't want to sit straight. But it will be straight later on.
skyfire
#12 Posted : 28 March 2013 02:23:05
I have added the lowest deck to the hull, not glued it in place just yet. I'll be gluing it into place soon and I'll try using some of the left over nails from the HMB Endeavour since issue 17 didn't come with any. Odd thing is issue 17 in the UK did comes with some small nails for the deck. Not sure when they will come out here, they are only used on the 1st deck.
skyfire
#13 Posted : 28 March 2013 02:23:49
Start of the lighting system.
skyfire
#14 Posted : 28 March 2013 02:24:33
Next deck has been glued in, next up is the lighting for this deck.
skyfire
#15 Posted : 28 March 2013 02:25:14
Lighting in progress on the next deck up.
skyfire
#16 Posted : 28 March 2013 02:25:54
Not sure how much more balsa I need to take off the bow section. ??
Jesus-Belzheim
#17 Posted : 28 March 2013 15:38:14
A nice start Skyfire BigGrin
I just hope you don`t get problems later on, your keel is not srtaight
Kind regards
Peter BigGrin
HMS Victory 1:84 DeA
skyfire
#18 Posted : 28 March 2013 16:49:10
It's straighter than it looks, also the front section is only just sitting there and is not glued in at that point.
Jesus-Belzheim
#19 Posted : 28 March 2013 19:14:08
It`s ok when it`s straight
It just didn`t look straight to me BigGrin
I just wanted to warn you
Now you would stil be able to change it, after the planking it`s to late Wink
Kind regards
Peter BigGrin
skyfire
#20 Posted : 02 April 2013 14:32:14
Also any bend in the hull has straightend itself out once the two decks were in place.
2 Pages 12>
This page was generated in 1.678 seconds.
