 Rank: Newbie  Groups: Registered
Quick hello. New to the forum and pretty much new to model building in general (unless Kinder eggs count?). Always wanted to build something like this one day though and I'm pretty good with my hands, or so the ladies tell me  , so why no jump in at the deep end? Up to issue 13 now and so far so good but I've hit a little snag. I'm planking the launch and I'm not happy with the finish. I'm going to cut some more of my own little balsa wood strips and start again because the problem I have is with bending the strips without breaking them up by the stern? Or is it the bow?  I mean the front bit lol. Any tips? I'm thinking maybe if I try to soften them by moistening them a little with water? Thanks in advance for any help you can offer
Hi Oli and welcome aboard. Many things can be learnt on the forum. Best is to soak the plank a little, attach and leave overnight to dry. If you have a soldering iron handy you can use that, just be careful not to burn the wood or yourself, or alternatively a plank bender will also do the job. Hope this helps. Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
Joined: 15/04/2010 Posts: 1,266 Points: 3,841 Location: The Quantock Hills,Somerset
Hello & welcome Oli,another way of bending the launch planks without soaking etc is to grasp them fairly tightly between thumb & forefinger nails & pull the plank though several times until the desired bend is achieved,you can also put a twist into the bend by altering the direction of pull.Hope this helps. Rob Nolli Illigitimi Carborundum!!!Current Builds: HMS Victory, SV Thermopylae
Hi Oli a big warm welcome to the Model Space Forum  You can achieve the bend of the planks with the methods Hans and Rob have mentioned, you can also hold a plank in tweezers over the spout of a boiling kettle, then as Hans suggests fit it damp without adhesive and when it is dry the shape remains, I hope that helps Kind regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Joined: 24/09/2012 Posts: 491 Points: 1,452 Location: London
Welcome oli, just like to say your kinder egg joke cracked me up, and i agree with the others, the planks are quite thin so best not to soak them for too long, good luck with your build! Processing - Progressing
Previous builds: HMS Victory Current build: HMS Sovereign of the seas
Thanks for the tips guys. Much appreciated :) I think I'll order a back issue to get some more planks and give it another whirl. I knew I was doing something wrong. All part of the learning process though :)
BTW anyone else had a little trouble with the subscriptions? I've been sent two No.18 issues and no No.14. Irritating? Just a little. Grrr...
Joined: 30/08/2012 Posts: 336 Points: 857 Location: London
Hi Oli,
Also as the planks are so thin, a normal plank bender will just break them, so stay from that for the launch, but they are fine for the main planking on the ship.
 Welcome aboard Oli Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Welcome to the forum Oli
A very warm welcome to the forum Oli, am sure you find all the information you need here.... Look forward to seeing your work... Regards Alan
[quote=budgie]  Hi Oli try this link hope it helps http://www.model-space.c...ctory-the-launch-build/[/quote] Great link  Much appreciated. Where I went wrong was trying to fit th e strakes without moistening them first. Broke the first two. Cursed a little. Tried again. Wood glue wouldn't hold. Cursed again. Opened a beer. Tried again. This time I used superglue to hold the beggars in place. That actually worked lol Not sure Admiral Nelson would have approved the final result though. I think the kindest thing I can say about it is that it probably wouldn't sink. Well...not immediately anyway. Thanks to everyone else for the warm welcome and all the other tips. :)
hi guys I'm IN SAME BOAT OR SHIP LIKE OLI. THIS FORUM IS VERY HELPFUL. THANK YOU FOR YOUR IDEAS
Welcome Sapuna
Joined: 06/12/2012 Posts: 152 Points: 439 Location: Barrow-in-Furness Cumbria
Hello Oli Hello Sapuna I also had an issue with the launch as this is my first attempt at this kind of model. Was pretty good at the Kinder stuff though. The advice you get on here is second to non and everyone is very willing to help. My advice with the launch is dont make the mistake i did by over sanding the outside. i ended up having to re order issue 8 and start again. it also initiated me to the forum and got some good advice. Cheers Stu Cheers Stu
Joined: 27/02/2013 Posts: 228 Points: 664 Location: Bursledon
Hi Oli I bent the launch planking just by dipping the ends in a glass of cold water for 15 minutes, then take out and stroke gently between your fingernails to get a bit of a curve, then soak again and repeat if necessary. Then pin them around something like a wine cork and leave to dry. I am only up to issue 9 and there was enough planking to finish the job with two strips spare. I think I will get some more planks with issue 10 and don't know why they are needed.
Guest (14)
