162 Pages «<3233343536>»
#661 Posted : 05 April 2013 22:25:09
Now finished the planking up to issue 31... Wasn't too happy with the pictures I posted last night, too dark and rather blurry. Retaken and posted again, these are a lot better... Now going back to work on the San Fran II and hopefully will have the infills completed before issue 32 comes out on Wednesday..... BigGrin BigGrin
#662 Posted : 05 April 2013 23:09:50
Good work AlanBigGrin nice and uniform, top job Kind regards Mike
#663 Posted : 05 April 2013 23:11:03
Thanks Mike... and I got your confirmation.....
#664 Posted : 05 April 2013 23:23:24
Lovely planking job there Alan, as said by MWG, really nice and uniform. The SOTS has beautiful graceful lines about her hull and you've captured them perfectly. Cool
She really does look like a warship of her time,the link between the Elizabethan galleons and the Georgian first rates! She'll be a stunning model! Drool
Well done!
#665 Posted : 05 April 2013 23:29:05
Well done!
Thanks for those kind comments Robin... I do love the way she is coming together but at the same time the feeling of aprehension is starting to creep in as we get closer to marking and cutting out the gun ports....Glare Glare .. Get that wrong and it will look awful.....BigGrin BigGrin .. Thanks again....
#666 Posted : 06 April 2013 13:06:48
All the comments you've been getting are well deserved Alan!
I agree the gun port cutting out is a daunting prospect but the actual 'doing' of it becomes surprisingly easy after the first couple.
I found the easiest method for myself was this way (I've never worked with bamboo planks however!)
After the gunport has been CAREFULLY marked out, drill a small hole in each corner about 2mm in from the pencil line, make sure the first hole is large enough for the router bit that follows!
Using a dremel type tool with a diamond dust router bit (either cylindrical or tiny ball end) start at one of the top holes and slowly grind down again 2mm in (might be worth drawing a second line 2mm in around the port come to think of it) until you reach the bottom hole, repeat on the other side and then the top and bottom horizontal cuts.
When you reach the last hole the inside ot the port should just fall out leaving you with a thin piece of wood to remove by careful filing AND THAT'S THE REALLY CAREFUL BIT!Crying
I found it easiest to have a pile of heavy books in front of the ship so I could rest my wrist holding the dremel and also guide the tool with the other hand too.
And thats all there is to it!Blink
If I were you and you have some spare planking I think I'd make up a little section of planked wall on a 1/2" square frame about 3" square or so and try it out on that first just in case the bamboo doesn't like the router!
Hope that's of some help and best of luck when you get there!
#667 Posted : 06 April 2013 13:19:59
Well done Alan Cool
#668 Posted : 06 April 2013 13:29:16
BigGrin Hi Alan
top work there she looks a treat
#669 Posted : 06 April 2013 13:47:40
Done a terrific job there Alan...Well Done!! ThumpUp
budgie
#670 Posted : 06 April 2013 21:24:32
BigGrin Crackin' job with the planking GandaleDrool Drool
You should be feeling chuffed with yourself
Cool Well done
#671 Posted : 06 April 2013 22:10:38
Hi Robin, once again thanks for the postitive vibes and for your guidance on the gun port issue... I do fully intend to carry out a few test sessions before finally attempting to cut any ports out on the old girl.... Cool Cool .. have the tools you describe so will give your method a try and hopefully post the results nearer the time..... Thanks again for all your help and guidance.....BigGrin BigGrin
#672 Posted : 06 April 2013 22:21:28
Tomick wrote:
Well done Alan Cool
Thanks Mr T, I have the spare planks to nearly finish planking the upper hull but am holding back the temptation.... Refusing to get ahead of the mags or your official diary..... thanks for keeping us all on the straight and narrow..... Cool Cool
#673 Posted : 06 April 2013 22:26:18
BigGrin Hi Alan
Thanks Andy, your comments are always welcome....
#674 Posted : 06 April 2013 22:29:18
Thanks Jonny and its really pleasing to see you back building again..... Thanks again for taking the time to look in.... BigGrin BigGrin
#675 Posted : 06 April 2013 22:41:46
Cool Well done
Thanks Budgie, yeah I do feel quite chuffed but am really looking forward to getting started on applying the final 2nd layer..... Thanks for looking in..... BigGrin BigGrin
der Gohfelder
#676 Posted : 06 April 2013 22:42:06
Uups, I missed your last progress, Alan!
It´s looking really great, you made a perfect job!
Regards, Bernd
#677 Posted : 06 April 2013 22:44:21
Regards, Bernd
Thanks Bernd, there is a lot to try and keep up with on this forum but think we all try our best.... Appreciate you looking in and for any comments you make..... BigGrin BigGrin
court orchard
#678 Posted : 07 April 2013 01:07:06
Looking Fantastic Alan. Don't worry about the Gun Ports in no time you'll be advising others how to do them.LOL
Admiral Anti Spiral
#679 Posted : 07 April 2013 01:45:17
looking great alan, not far until those gun ports come along, personally i cant wait to start, though i did a test with a cheap rotary tool i managed to buy, using the cutting disk is handy because it gives a straight cut but its not as easy as i thought, but much easier than doing it by hand i suppose, im sure it will come along nicely!
Processing - Progressing
Previous builds: HMS Victory
#680 Posted : 07 April 2013 23:06:52
Thanks for the words of encouragement Andy, very much appreciated..... I'll just be relieved when I get the first one cut out without any mishaps, then I'll know if I can tell my knees to stop knocking....LOL LOL LOL
Guest (19)
This page was generated in 0.739 seconds.
