17 Pages «<7891011>»
#161 Posted : 07 April 2013 01:41:14
That'll be the Front, Centre, Rear and Catapult Sets I guessBigGrin
you would be spot onCool Love
#162 Posted : 07 April 2013 02:20:47
11 Meter Launch
Total build time 63 hours
Whilst i am waiting for more etch to be delivered I decided to make a start on the ships boats. The 11m Launch comes as a 4 pice in the kit. I have seen some uncomplimentary comments on the web about these but i don't agree, i think they could paint up rather nicely. The MK1 upgrade set however is an improvement replacing the top of the boat with 19 etch pieces. I used the kit supplied etch propeller as it is thicker and easer to form the blade angles. I chose to paint the etch on the fret before building, not essential to do that although you will need to paint the inside of the cabin prior to fitting. The hull and steel work are all the same grey as the superstructure i have used WEM colour coat U.S Navy Mahogany Flight Deck Stain for al the wood work and Schiffsbodenfarbe Rot 5 for the lower hull leaving the propeller in Brass.
The Ships boats should all be lashed down with a combination of webbing and chain - may have to play with scratch building that as nothing in the etch sets so far. The two flag staffs will be added when the boats are fitted to prevent any damage.
As always any Constructive comments greatly appreciated Cool
#163 Posted : 07 April 2013 10:24:31
BigGrin Hi Jase
As always the etch makes all the difference, Top work keep the pic's coming
court orchard
#164 Posted : 07 April 2013 11:36:26
Hi Jase,
Can I ask, what do you prime your etch with?
#165 Posted : 07 April 2013 13:13:06
court orchard wrote:
Hi Jase,
Hi Andy,
All depends on the application and the etch. I use Humbrol number 1 grey primer for enamel paint as a rule but only on larger small parts if that makes senseLaugh . smaller parts with fine detail i tend to just paint without priming so i don't lose the detail. if the etch is part of a larger construction then I may prime the whole thing in one go I use Halfords white primer for that, but again may add the finer detail later. In the last few years I have moved away from Acrylic paints, although you can get a more even brushed surface and they are less noxious there not as hardy and i have had problems with thinning and multi coating, I find they clog more easy, my way of working is to paint components before assembling. I tend to spend a moment planning the build of each sub assembly and decide what is being painted when and if I will prime or not. Generally i find there is less need to prime enamel paints that are more hardy than acrylics .
I did not prime the ships boats at all, usually I would have primed the deck parts and not the smaller detail. This time however I wanted the brass to come through the thinned paint a little to give a wood type depth which I think worked well, The deck paint was quite thin so had three coats thinned at 6 parts paint to 1 part thinner. the reveal (grey) paint has a much higher viscosity so was thinned at 2 parts to 1 and only needed two coats.
Hope that helps
J
court orchard
#166 Posted : 07 April 2013 19:51:14
Thanks Jase, I didn't expect such a comprehensive answerBigGrin BigGrin. I'm planning on Airbrushing most of the build and am thinking of a Tamiya primer followed by Acrylics from Lifecolor with possibly a protective sealer, maybe Purity Seal from Citadel (mainly because I have a large can). The detail on the Mk1 Etch is so fantastic, i think my brushwork would mask too much of it.
Warthog
#167 Posted : 07 April 2013 22:28:55
If your going to be airbrushing then i would suggest ZeroPaints Micro white and Grey Primer... goes a hell of a long way and will not hide any detail.. Tamiya primer tends to be "thicker".. Just a suggestion from Experience BigGrin
#168 Posted : 07 April 2013 22:38:05
I usually dry brush fine detail like grills etc. so far my experiance with an airbrush has meant bining the model Crying always got lots of spatter although thinking about it only ever used it with Acrylics. i might buy a cheep airfix kit to have a play Glare
court orchard
#169 Posted : 07 April 2013 22:51:26
Yeah I've had splatter too, but with a bit of practice and the right thinning it, for me anyway, gave superior results. I've just upgraded my compressor to a tanked one and that gives a much more constant feed without the pulsing effect I had with the old one. The last thing I Airbrushed was some Warhammer 40K Floating Tank ThingLOL LOL and it gave really good results.
#170 Posted : 08 April 2013 13:28:58
spent the whole of last night cross refrencing my Kit instructions with my two etch set instructions and my now huge pic refrance libary.
I am now ready to start removing the plastic that I am replacing with etch and planning any scratch build materials. I have drawn a line on spending for this kit so wont be buying any more upgrades - probablyBlink BigGrin Laugh
court orchard
#171 Posted : 08 April 2013 15:29:07
Did you spot the missing View Port at the front of the Foretop Artillery Post.
#172 Posted : 08 April 2013 17:03:33
oow no have you got a pic please
court orchard
#173 Posted : 08 April 2013 18:53:56
Now this is interesting, Anatomy of the Ship shows it clearly on Pg63. However it's not on the Kagero Drawings or Pictures. Because it's right at the top under the FUMO Radar, it's obscured from the deck so it's not visible in any photos I have been able to find.
It's the part C2.
It makes sense that it would be there otherwise they would've had no view directly forward.
#174 Posted : 08 April 2013 20:56:48
[quote=court orchard]Now this is interesting, Anatomy of the Ship shows it clearly on Pg63. However it's not on the Kagero Drawings or Pictures. Because it's right at the top under the FUMO Radar, it's obscured from the deck so it's not visible in any photos I have been able to find.
It's the part C2.
Yes I think it should be there. had a quick look at some Tirpitz pics online and you can see a forward slot on her and in a couple of Bismarck picks when i expand you can just make a out a shadow or something slightly darker.
court orchard
#175 Posted : 08 April 2013 21:55:48
It's the part C2.
I agree definitely there on the Tirpitz on 2 photos in Breyer and Skwiot. As you say there are a few photos taken from a distance of the Bismarck were there's something there, but not good enough resolution to resolve into a slot. It's on several other drawings in the Anatomy Book too.
#176 Posted : 09 April 2013 01:27:02
BigGrin Hi Jase
I have some references to it on my plans and im pretty sure Ballards book has an eye view picture not an artists inpresion of this area with the forward position fittings in place the scope part being shot away so just the hole left
#177 Posted : 11 April 2013 00:20:55
Lower forward superstructure preparation.
Total build time 66.5hours
Started preparing the superstructure in preparation for adding the etch and some scratch built detail. Scuttles have been drilled out and the covers removed. most of the vents and covers have also been removed. i have left the doors on for now but i do have replacement etch doors on their way from Germany, but I will wait to see how many I have first before i remove the moulded ones BigGrin I have also removed some of the deck that will be replaced by the Eduard etch where it overhangs the superstructure.
I have also striped down some scrap electrical cable ready to add some of the missing cabling. Once i have some clearer plans and my remaining etch arrives I can start to put this together.
#178 Posted : 11 April 2013 09:43:22
Lovely stuff there Jase. You obviously put a lot of thought into this and have the patience of a saint.
#179 Posted : 12 April 2013 21:29:06
Thanks Hans, yes i do put a lot of thought in, not sure about the patience though Blink
#180 Posted : 12 April 2013 21:47:01
Bit like Christmas today received my delivery of plasticard, strip and rod ready for some scratch building and I received 4 sets of eduard etch.ThumpUp
There is plenty of aditional bits that will compliment the MK1 set and some duplication. of the duplicats some are nicer detail others not. the etch is much thiner and therfore more delicat than the trumpeter and MK1 etch, and some very fine detail indeedHuh Mellow . oh and som figures!! going to reserve judgment they are pre painted and i probably wont use them but we will see.
Guest (6)
This page was generated in 0.642 seconds.
