33 Pages 123>»
willz buildz Options
willz
#1 Posted : 21 May 2010 00:21:32
Active Service Medal: 500 post active service MedalTurquoise Medal: Turquoise Medal for model making know-how contributionOutstanding Build: An award for an outstanding buildBuild-Diary Medal: Build-Diary Medal of Honour
well almost up to speed with the launch. broke the last rib (at rear) sanding to get the contour right, stuck it back on, but it broke again in seperation from jig (blahh)
done the planking, tapered wrong way on starboard side but did it right on port side. Its the last piece thats the hardest.
i have a pic of her but dont know how to post them, (not much of a computer buff)the admins instructions are as clear as mud, and as many times i follow them i get the same result,! psgu0r KWQp[ kosg e45q qd cmxlpo3 f[sdkjf,ma
launch planking.jpg (315kb) downloaded 610 time(s).
willz
#2 Posted : 21 May 2010 00:29:23
managed to post the pic but no idea how i did it,,
ok its the last plank you fit that is the hardest, on my pic its the 3rd one down from the top, it starts and finishes within the launch very fiddly, the third and forth planks are thinner to accommodate for the acute angle of the ribs at this point.
I need to double up the top plank, i left this till last because of all the sanding of the hull, didn`t want to sand the sharpness out of the bottom edge. also its easier to scribe it to keel (water cutter) than to cut the keel (water cutter) round the double planking at the top. so thats my tips at this stage
willz
#3 Posted : 21 May 2010 02:14:23
The end result looks great Willz, Not a gap to be seen, and it's a very neat job.
Dontshootme
#4 Posted : 21 May 2010 10:18:47
Very nice,just hope mine turns out just as good.Crying
Mac
#5 Posted : 21 May 2010 13:13:16
A very nice clean build willzBigGrin
Pam's shipyard is closed for now no more room!
dtgray
#6 Posted : 21 May 2010 17:53:12
Very nice work so far willz BigGrin
David
budgie
#7 Posted : 21 May 2010 18:03:51
Cool good job there
thanks for the pic makes things a bit clearer for me
willz
#8 Posted : 21 May 2010 21:11:11
heres a pic of the starboard side of the launch, as you can see i started to taper the planks the wrong way ( the third and fourth from the top.
managed to still do a neat job but the run of the planks doesn`t look right (blahh)!
just a point on the rubbing strips, when sanding they soon disappear, so caution is required on these..
starboard planking flaw.jpg (345kb) downloaded 365 time(s).
starboard planking flaw.jpg (345kb) downloaded 254 time(s).
willz attached the following image(s):
willz
#9 Posted : 21 May 2010 21:59:16
ok my anchor, i decided to leave the stock in natural wood (can always paint it later if i choose).
i used wood for the bands instead of the thread supplied, my first wooden built so the practice is needed.
made a bigger ring out of brass wire, i puddened the ring before bending it round a pen.
filed the anchor down to rid the flaws, then painted it with a black paint which had been mixed with white to take the strenth out of the black. (at this scale pure black is too stark, so although the photo looks black it is in fact far from it.
then varnished it with a satin varnish, (again gloss not right for scale) still think the satin varnish is still too shiny
then matt varnished the stock left to dry, masked up the four bands, now at this point i matt varnished the masking tape joint, this seals the masking tape and any bleed will be the matt varnish, If your masking the side of victory for instance the yellow from the black then paint the masking joint yellow any bleed will be of the base coat yellow and the masking tape is sealed, although you can always touch it up when using paint, with the natural wood of the stock i thought better to seal the tape
budgie
#10 Posted : 21 May 2010 22:08:03
Drool looking really good
tf5600
#11 Posted : 21 May 2010 23:14:26
Looks great, nice neat work,
Ferret
Capt Stedders
#12 Posted : 22 May 2010 00:19:27
Nice, tight work on the launch planking.
The anchor is also very tidy - especially the neatly contoured ends
Great stuff. Cool
Schnellboots on back burner
Tools.
willz
#13 Posted : 23 May 2010 23:40:53
thanks all for your comments much appreciated, by the way what do you all think of my avatar, i painted this myself some 30 years ago from a book cover (swagger swagger)
tf5600
#14 Posted : 24 May 2010 00:19:31
Brilliant !!!
willz
#15 Posted : 25 May 2010 02:26:03
here`s one i did about ten years ago, originally done by my favourate artist john atkinson grimshaw born in leeds in 1836
Jamie
#16 Posted : 25 May 2010 10:41:24
Very impressive....paintings and all ThumpUp
I wish I were a glow worm,
A glow worm's never glum,
'Cause how can you be grumpy?
When the sun shines out ya bum!!
willz
#17 Posted : 02 July 2010 02:37:03
the cutty sark, model done in 3DS, scene done in VUE 4, i placed the ship too high out of the water, but what the hell.
jay7792
#18 Posted : 04 July 2010 18:44:18
Hello mate, it looks good to me, well done.BigGrin
_____________________________________
Currently building:-
Deagostini HMS Victory
Amati Black Pearl
Mamoli HMS Victory 1:90 Scale
Caldercraft HMS Victory 1:72
willz
#19 Posted : 05 July 2010 12:27:06
the launch so far
Mike Turpin
#20 Posted : 05 July 2010 13:44:46
Hi Willz
That's a very neat job and yet another variation on the theme of how to finish the launch!
Well done
Mike TBigGrin
Guest (11)
33 Pages 123>»
This page was generated in 2.597 seconds.
