Will the engine be built from scratch? ie. piston..crank...internals etc or will it come whole minus muffler etc
 Hi Swine I think Mr T has said previuosly that the engine comes in parts to be assembled ' I imagine the smaller parts such as the piston and con rod, carb will come pre assembled so its a case of putting finished item's together to make the whole engine. Although im sure Mr T will confirm this. Hope this helps regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Correct Andy, internal are to install into the crankcase
 Rank: Pro        Groups: registriert
Joined: 13/03/2012 Posts: 306 Points: 847 Location: Germany
Good morning Just want too tell the Engine will take 12 Issues . Sorry for my Bad Englisch . I wish everybody Success by building the red-bull Rb7. We are now by Issue number 58, And i can tell you its heartbeat every week when a new issue arrives. With issue number 20 you will get a Explosion-Drawing from every Part off the 100 issues, including the numbers so you can see when which issue arrives. Greetings and success too everyone Andreas Forum Support Team http://www.model-space.com/de/
 Hi Andreas welcome to the forum and thank you for the information most of all enjoy your build regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
