Engine build Options
SWINE
#1 Posted : 10 April 2013 15:10:25
Will the engine be built from scratch? ie. piston..crank...internals etc
or will it come whole minus muffler etc
#2 Posted : 10 April 2013 15:17:07
BigGrin Hi Swine
I think Mr T has said previuosly that the engine comes in parts to be assembled ' I imagine the smaller parts such as the piston and con rod, carb will come pre assembled so its a case of putting finished item's together to make the whole engine. Although im sure Mr T will confirm this. Hope this helps
#3 Posted : 10 April 2013 15:19:25
Correct Andy, internal are to install into the crankcase
Andreas
#4 Posted : 28 April 2013 08:57:15
Groups: registriert
Good morning
Just want too tell the Engine will take 12 Issues . Sorry for my Bad Englisch . I wish everybody
Success by building the red-bull Rb7. We are now by Issue number 58, And i can tell you its heartbeat every week when a new issue arrives. With issue number 20 you will get a Explosion-Drawing from every Part off the 100 issues, including the numbers so you can see when which issue arrives.
Greetings and success too everyone
Andreas
Forum Support Team
#5 Posted : 28 April 2013 09:55:02
BigGrin Hi Andreas
welcome to the forum and thank you for the information most of all enjoy your build
