10 Pages <12345>»
moriarty,s HMS Victory renovation project Options
#41 Posted : 08 April 2013 23:50:55
Looking good Moriarty, as always.... loving your work....BigGrin BigGrin
#42 Posted : 09 April 2013 09:30:02
Good build there Moriarty. like the innovation. One to be filed away for future reference.
moriarty
#43 Posted : 11 April 2013 12:40:23
Another small update guys. I have decided to do away with the supplied beakhead parts and build my own. I am going the way of the Jokita victory for some of these(thanks for posting the pics Karl been a big help)so this is the start.BigGrin
HMS Surprise
HMS Snake
HMS Bounty
HMS Royal Caroline
HMS Victory rebuild
HMS Supply
#44 Posted : 11 April 2013 12:46:18
you need to make sure that the gap left, is wide enough to accept the decoration. looking good though. k.
#45 Posted : 11 April 2013 12:53:09
karl1113 attached the following image(s):
moriarty
#46 Posted : 12 April 2013 14:06:45
Thanks for the pic Karl and the heads up on detail but unfortunately this one did,nt come with that detail unless I make it myself or something. Another update on the beakhead which is becoming almost scratch built. Made new decking and sunk the panels into it. Once it is painted ,it wont look so badBigGrin
HMS Surprise
HMS Snake
HMS Bounty
HMS Royal Caroline
HMS Victory rebuild
HMS Supply
moriarty
#47 Posted : 12 April 2013 14:09:11
Some of the salvaged parts were damaged in an accident a few years ago when I was flexing my muscles on this thing so repairs were adamant.BigGrin
HMS Surprise
HMS Snake
HMS Bounty
HMS Royal Caroline
HMS Victory rebuild
HMS Supply
moriarty
#48 Posted : 12 April 2013 14:11:09
The all new deck completely different from the original. The one above this will be remodelled also.BigGrin
HMS Surprise
HMS Snake
HMS Bounty
HMS Royal Caroline
HMS Victory rebuild
HMS Supply
skyfire
#49 Posted : 12 April 2013 14:37:07
Looks like your going well with her. :)
moriarty
#50 Posted : 12 April 2013 15:09:54
Another update ,tried out the coppering round the base dowels. Seems to work well.
HMS Surprise
HMS Snake
HMS Bounty
HMS Royal Caroline
HMS Victory rebuild
HMS Supply
moriarty
#51 Posted : 12 April 2013 15:11:40
Just a sanding down now and it is ready for a paint jobBigGrin
HMS Surprise
HMS Snake
HMS Bounty
HMS Royal Caroline
HMS Victory rebuild
HMS Supply
moriarty
#52 Posted : 12 April 2013 15:13:18
This front view says it all to me. 100 times better than I originally did it.BigGrin
HMS Surprise
HMS Snake
HMS Bounty
HMS Royal Caroline
HMS Victory rebuild
HMS Supply
#53 Posted : 12 April 2013 22:13:04
Fantastic progress there Moriarty! I know all about the beak heads from the DelPrado! They're real Cursing Cursing Cursing 's to scratchbuild but the result makes or breaks the entire bow of a ship like this. Yours is definately a 'maker'!
Well done!
#54 Posted : 12 April 2013 23:52:40
Great work there Moriarty, bow is really starting to look the business... Look forward to seeing her progress.... BigGrin BigGrin
moriarty
#55 Posted : 13 April 2013 15:37:33
Thanks for the praise boys, you all know how fiddly these beaks can be. Another update . Been putting the paint on the beak , starting to look the now I reckonBigGrin
HMS Surprise
HMS Snake
HMS Bounty
HMS Royal Caroline
HMS Victory rebuild
HMS Supply
moriarty
#56 Posted : 13 April 2013 15:41:40
The panel on the bulkhead comes as a more or less a printed piece of veneer and is wafer thin, not a lot I can do about it but the amount of rigging and stuff that goes into this area will hide most of it (hopefully)BigGrin
HMS Surprise
HMS Snake
HMS Bounty
HMS Royal Caroline
HMS Victory rebuild
HMS Supply
#57 Posted : 15 April 2013 10:38:14
Beautiful job the Moriarty, beautiful job. No need to second guess yourself my friend.
moriarty
#58 Posted : 17 April 2013 11:40:47
Another update now guys. The guns on this kit are a bit on the sparse side and I only have 8 of these and 6 smaller ones. Here are the 8 fitted in place. The plank running along the top is to compensate for the extra hieght in the decking, a difference of nearly 2mm so it would have looked stupid leaving it as original.
HMS Surprise
HMS Snake
HMS Bounty
HMS Royal Caroline
HMS Victory rebuild
HMS Supply
moriarty
#59 Posted : 17 April 2013 11:43:50
The main deck as it stands at the moment. I have made this so I can just slot it in when the bottom deck is complete. Most of the deck detail on this one will probably be fitted off ship.
HMS Surprise
HMS Snake
HMS Bounty
HMS Royal Caroline
HMS Victory rebuild
HMS Supply
moriarty
#60 Posted : 17 April 2013 11:48:13
Just a little tip guys. If you are running short of cannonballs a good thing to use is fishing lead weights as I have done. They come in big trays and will cover just about any scale and caliber. Select squeeze and install simples. They can also be used for the running bearings on mastsBigGrin .
HMS Surprise
HMS Snake
HMS Bounty
HMS Royal Caroline
HMS Victory rebuild
HMS Supply
Guest (12)
10 Pages <12345>»
This page was generated in 0.449 seconds.
