162 Pages «<3435363738>»
#701 Posted : 13 April 2013 00:26:48
NMBROOK wrote:
The ports are 13mm wide by 12mm high.The italian instructions suggest drilling small holes against the top of the deck from the inside and the same against the bulkheads from the inside.I did this with a 0.5mm drill in a pin vise(you cant get dremel etc inside hull).I drilled a hole every 10-15 mm.Then its a case of joining the holes dot to dot style on the outside with a pencil,i clamped a piece of 4mm square lime for the deck levels as this gives a nice flowing curve.Because of the tumblehome (onion shape)of the hull the second decks ports are in a face with about a 20 deg slope,i kept the size gauge horizontal so the port is actually higher if you measure on the sloping face of the hull.Having cut all mine out now i have decided to reduce the port size on the top deck to 11mm wide by 10mm high,as it just looks top heavy and the gunports should decrease in size a you go up decks.as mine are cut i'm just going to line the top ports with 1mm strip,this part is black so will be covered.I hope you can understand my waffle and thankyou for your encouragement,
Regards Nigel
You see, ask questions on this forum and the majority of times the answers will flow in..... Fully understand your guidance but would ask, can you get a pin vice in between the dummy gun supports and the planking... not a lot of room in there or am I missing something... Don't see a problem doing that with the bulkheads..... Thanks for the guidance Nigel, really do appreciate it......BigGrin BigGrin
NMBROOK
#702 Posted : 13 April 2013 01:58:52
You do not need to drill holes along the bottom deck it is the next deck up you need.Deagostini work from this line and give dimensions so you can mark the line of the lower deck on the outside of the hull.Indeed all vertical dimensions are set out from this second gundeck.
Glad i can help
Nigel
#703 Posted : 13 April 2013 09:50:28
Glad i can help
Nigel
Thanks Nigel, that makes it a lot clearer and now feel happier with the progress that lies ahead.... Thanks again...BigGrin BigGrin
#704 Posted : 16 April 2013 22:00:56
BigGrin Hi Alan nice build can't wait to cut the gun port'sLaugh wot am i sayingBlink HAPPY BUILDINGBigGrin
#705 Posted : 16 April 2013 22:49:56
Yep Martyn, think you are bordering on the side of lunacy.....LOL LOL Flapper LOL LOL ... Thanks for the nice comment and taking the time to look in.... BigGrin BigGrin
#706 Posted : 17 April 2013 14:47:44
Laugh Gun port's WE LOVE's them WELOVE's them my preciousLOL LOL LOL ThumpUp
#707 Posted : 17 April 2013 22:58:48
LOL LOL Martyn, lets see if you are still saying the same thing when you are half way through....Huh Huh ... Must admit though, am quite looking forward to getting to work on the first one, that will tell us how it's going to go....BigGrin BigGrin
#708 Posted : 19 April 2013 23:44:57
No work done last night due to other demands on my time...Cursing . Started tonight by laying 2 layers of planks on either side of the upper hull. BigGrin For the third layer I first fitted the plank running from rib 16 to the stern, then cut a length to run from midway between ribs 5 & 6 to 16, tapered the plank ensuring the taper run the full length of the strake... Glued in position and when dry blended the taper to run onto the previous plank... Hopefully tomorrow will fit the third layer to the other side and finish planking up to issue 33..Cool Cool
Happy building all....
der Gohfelder
#709 Posted : 20 April 2013 05:05:59
Hi Alan!
That's absolutly superb work! I would be proud, if my model would be as perfect as yours!
Regards, Bernd
#710 Posted : 20 April 2013 08:11:15
BigGrin Bril work Alan . Love the plankingLove Love Regard's Martyn
#711 Posted : 20 April 2013 19:17:07
der Gohfelder wrote:
Hi Alan!
Regards, Bernd
Bernd, thank you for that wonderful comment, really is appreciated... Think I still have a long way to go to reach your very high standards but it is what I am aspiring too..... Cool Cool .. Thanks again for the encouragement....
#712 Posted : 20 April 2013 19:18:43
Thanks for looking in Martyn and for the encouragement.... First layer of planking should be complete with the next issue so we are getting close..... Get your sanding arm ready..... LOL LOL
court orchard
#713 Posted : 20 April 2013 19:20:29
You're Storming ahead Alan, Great WorkThumpUp
#714 Posted : 20 April 2013 19:22:24
Thanks Andy, appreciated. Still think I will hit a wall somewhere but so far so good..... LOL LOL
court orchard
#715 Posted : 20 April 2013 19:28:55
Nah, you'll be like Ewan McGregor at the end of 'Men Who Stare at Goats'.LOL LOL
#716 Posted : 21 April 2013 03:40:33
Hi Alan great workBigGrin ,well done Kind regards Mike
#717 Posted : 21 April 2013 09:16:41
LOL LOL ... Great response Andy.... had me chuckling away......
#718 Posted : 21 April 2013 09:17:45
Appreciated Mike, as always....
#719 Posted : 21 April 2013 23:39:11
Finished the planking as per issue 33 and moved onto to sealing the gap between the gallery and the stern planking... Cut a section of bamboo to fit and using steam from the kettle induced a bend in the plank to fit the curvature of the gallery....
Using a sanding block, removed the rounded edge of the bamboo to ensure a snug fit with the gallery profile.... When happy with the fit glued and pinned in place.... final shaping and sanding to be done tomorrow...
Finally trimmed the planking overhanging the stern.. BigGrin BigGrin Happy building all....
#720 Posted : 22 April 2013 11:19:50
Good job there Alan, she is coming along nicely.
Guest (6)
This page was generated in 0.236 seconds.
