56 Pages «<4950515253>»
MWG build diary of the mighty Hood Options
#1001 Posted : 15 April 2013 22:36:13
ISSUE 67 TO 69
Hi Everyone, what follows are the photos of the continuation and finish of the above issues:-
#1002 Posted : 15 April 2013 22:49:03
ISSUE 70
Continuing the build of the centre deck:-
#1003 Posted : 15 April 2013 22:51:21
Looking good Mike ThumpUp
#1004 Posted : 15 April 2013 22:52:23
ISSUE 71
More build of the centre deck:-
#1005 Posted : 15 April 2013 22:56:08
ISSUE 71
Thata all for nowBigGrin Kind regards MikeBigGrin
#1006 Posted : 16 April 2013 00:48:11
Hi Jase, thank you for the kind commentsBigGrin Best wishes Mike
#1007 Posted : 16 April 2013 10:09:11
BigGrin Hi Mike
looking good, there's more small detail on her than I expected
Gaz
#1008 Posted : 16 April 2013 12:03:17
Looking good MikeBigGrin.
You are at about the same stage as myself. How did you find painting the small white metal bits? I found that for the primer to take I had to give them all a good rub down with some very fine wet and dry paper to remove any manufacturing residue.
Gareth
#1009 Posted : 16 April 2013 12:26:19
Gareth
Hi Gaz Thank you for your nice comment.I did not use primer I clean all the parts with nail varnish remover and apply two coats of paint by brushBigGrin I hope that helps you
Kind regards Mike
#1010 Posted : 16 April 2013 13:26:02
Hi Mike.
Looking very nice. The detail is starting to show on the bulkheads.
Looks very impressive.
IanCool BigGrin
Jesus-Belzheim
#1011 Posted : 16 April 2013 16:25:28
You`re doing great Mike, nice work ThumpUp
Kind regards
Peter BigGrin
HMS Victory 1:84 DeA
#1012 Posted : 16 April 2013 20:24:33
BigGrin Hi Mike
Hi Andy there certainly isBigGrin thank you for looking in and your nice comment. Kind regards Mike
#1013 Posted : 16 April 2013 22:20:54
Hi Peter, thank youBigGrin how are you? kind regards Mike
#1014 Posted : 16 April 2013 22:33:52
This is coming together very nicely Mike, high standard as usual....BigGrin BigGrin
#1015 Posted : 17 April 2013 00:18:19
Hi Alan Thank youBigGrin kind regards Mike
#1016 Posted : 17 April 2013 21:31:24
ISSUE 70 AND 71
Hi this time I am putting some final touches to these issues, the photos should explain all, watch for the Port and Starboard additions to the centre deck and the 6 round dowal supports which will support the next deck (which believe it or not will cover all the detail I have just finishedBlink
court orchard
#1017 Posted : 17 April 2013 21:38:27
Excellent work Mike.
I thought for a second that those were Toilet Rolls and you were modelling the HeadsLOL
#1018 Posted : 17 April 2013 21:39:21
Huh This is the deck that now covers all the detail. thats all for now, Kind regards Mike
#1019 Posted : 17 April 2013 21:41:22
Fantastic work Mike! Will you be weathering or a clean build?BigGrin
#1020 Posted : 18 April 2013 08:28:14
Hi Andy thank you for your nice commentsBigGrin you could be right, kind regards Mike
This page was generated in 0.342 seconds.
