 Rank: Beginner Level 3   Groups: Registered
Joined: 02/04/2013 Posts: 29 Points: 77 Location: Ireland
Hi again. Just looking at some of the builds. I've noticed planking done on the 2nd deck? Is this an optional addition to builds or still to be done in later issues? Is this planking the same wood dimensions of the hull planking? Thanks again Regards Jay
Its not in the instructions and is down to personal choice, but dont use similar to the hull planking as its way too thick.
Experienced builders tend to go their own route with adding enhancements or changes to the intended build.
Tomick wrote:Its not in the instructions and is down to personal choice, but dont use similar to the hull planking as its way too thick.
Experienced builders tend to go their own route with adding enhancements or changes to the intended build. Thanks Tomik. Any more progress on your build Thanks Jay
Just for you...
Tomick wrote:Just for you... haha. nice 1. coming on nicely.
Joined: 27/02/2013 Posts: 228 Points: 664 Location: Bursledon
Some builders have been planking the second deck, as a practice run at techniques of construction and finishing. I don't think any of the second deck will be visible on the finished model, if done as per the official build. If you are going for some lighting on the gun-decks, this planking might just be visible through the deck gratings, if you decide to cut the upper deck out under the gratings. You would have to really squint at it from directly above to see anything though. This would be a modification to the official build - up to you.
 Hi jpda I did some on mine just for the practice Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
Thanks for clarifying guys. Looks good martyn. Regards. Jay
 Happy to help.Good luck with the build Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
