14 Pages «<7891011>»
sandnesspeats Options
#161 Posted : 18 April 2013 00:42:32
sandnesspeats wrote:
hi karl,
I tried to delete and re post but it would not show them. this is the first time this has happened, don`t know how this has happened as I have not changed the settings on the camera. if you can help how to change the size of them so it will show that would be great.
thanks
rob
click on your pics first,select the one you want to put up,then click on edit pic, go to resize, change to 800x600 then save, click on post a reply, put a tick in the attach file box, click post, and another box appears,
#162 Posted : 18 April 2013 00:45:33
hi karl,
thanks
rob
click on your pics first,select the one you want to put up,then click on edit pic, go to resize, change to 800x600 then save, click on post a reply, put a tick in the attach file box, click post, and another box appears,hit the choose file button,and select the resized pic and hit the upload button,you can then select another resized pic. when finished hit the back button to load pics on reply page.
sandnesspeats
#163 Posted : 18 April 2013 11:14:30
here goes with the photosBigGrin BigGrin BigGrin
Thanks Karl for your info.
sandnesspeats attached the following image(s):
sandnesspeats
#164 Posted : 18 April 2013 11:23:07
karl1113 wrote:
ok rob,the hole is def. not in the middle is it. so a bit of back tracking required, replace some deck flooring and start again,cut dead centre hole,before gluing,you might have to go lower down,to widen lower deck hole to get the mast straight. leave it any longer and will be too late to fix.
good luck,and take the repair as a phase in the building. k.
Hi karl,
The thing is that everything is glued,never thought to check before putting the cabins inBlushing Blushing Blushing. It was only when I measured the center line that I found out about it being off,I was horrifiedCursing Cursing Cursing
Thanks again
DaDokta
#165 Posted : 18 April 2013 13:04:08
Ouch, that hurts!!
It should be no big problem to adjust the poop and the quarter deck.
But the lower decks won`t be easy - a long file is all that i can think of.
I wish you the best of luck.
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
sandnesspeats
#166 Posted : 18 April 2013 14:14:43
Hi dadokta,
thanks! you can say that again it was a sore one.
I do have long round file hope this will do the job slowly but surely. I hope it is hidden after I have finished adjusting it.
cheers
rob
#167 Posted : 18 April 2013 22:54:48
Rob, so sorry to see this problem with your build, Crying Crying really hope it works out for you... Take your time on this repair, double check all your measurements before starting to cut... Once you have the mast in the correct position replanking part of the deck should cover most of the repair....Blink Blink . Fingers crossed for you as your build is really coming on a treat.....Cool Cool
sandnesspeats
#168 Posted : 18 April 2013 23:16:42
Thanks for that Alan,
I suppose this is the cause of first time building of this type, I posted this earlier and thought I had it but obviously never checked it enough,just have to see what I can do with it and check the other two masts at the same time.
I will post after the big BigGrinOPERATIONBigGrin.
Thanks again for the confident remarks.
rob
#169 Posted : 18 April 2013 23:36:33
Rob, would suggest you take some pics as you progress with the repair, keeping these in reserve in case you need to publish to get some more advice as to the best way forward..... Will be keeping everything crossed for you for a successful repair.....Cool Cool
#170 Posted : 19 April 2013 09:08:31
Hi Rob, feel your pain. as the others have said take your time re-measure and repair, good luck and wishing patience ad success.
sandnesspeats
#171 Posted : 19 April 2013 11:17:36
Thanks Hans,
I like your quote makes us think we are all humanMellow Mellow
Just have to see what happens, I will post pics just in case any new builder comes on, something to look out for.ThumpUp ThumpUp
cheers again
rob
sandnesspeats
#172 Posted : 19 April 2013 11:19:47
Thanks again Alan,
will post pics as I said earlier to help newbies to watch out for in their build.
cheers
rob
BigGrin BigGrin
sandnesspeats
#173 Posted : 19 April 2013 22:55:31
I think I am there, the center mast was off too, don`t know if you can see them properly so here goes. I put some balsa wood to hold it place for the time being.Blink Blink
#174 Posted : 19 April 2013 23:11:43
that looks soooo much better,well done that man, give yourself a good pat on the back.Cool Cool k.
#175 Posted : 19 April 2013 23:12:10
Now that looks much better Rob, well done.... when finished doesn't look as if it will be noticed....BigGrin BigGrin
sandnesspeats
#176 Posted : 20 April 2013 00:16:57
Thanks Karl a bit fiddly but got there.
great inputBigGrin BigGrin BigGrin
rob
sandnesspeats
#177 Posted : 20 April 2013 00:20:37
Thanks Gandale,just have to tidy it up now.
thanks for the inputBigGrin BigGrin
rob
DaDokta
#178 Posted : 20 April 2013 19:53:59
Noone will ever notice, once you are finished!
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
sandnesspeats
#179 Posted : 20 April 2013 22:37:11
Hi DaDokta,
I was afraid it might have been seen, but gladly you verified it for me.Cool Cool
thanks again
rob
sandnesspeats
#180 Posted : 24 April 2013 14:41:34
Hi all,
I have a gap on the sides on the top deck and nothing to lay a plank on to, I have put a bit of wood level with the planking on the side. Could anybody tell me if this will interfere with anything later in the build.
Thanks in advance
rob
This page was generated in 2.651 seconds.
