14 Pages «<56789>»
Yet another Victory by Bernd Options
DaDokta
#121 Posted : 18 April 2013 08:55:07
Amazing work, Bernd!
Thanks for the tip with the additional holes - will use that once i get there.
Cheers,
Walter
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
#122 Posted : 18 April 2013 12:15:25
Excellent job there Bernd. Looks so crisp and clean.
Bernd
#123 Posted : 18 April 2013 23:19:06
Thanks, everyone, for having a look at my build diary!
Next on my list was adding the shrouds
and deadeyes ...
and binding some 120 deadeyes to the ends of the shrouds, this being the first one:
At the same time, to have some job variation, I started with the hammock nets
Bernd
#124 Posted : 18 April 2013 23:19:45
Following the suggestions of others, I left a "pin" at the bottom of the hammock cranes
and drilled holes to help with the correct placement of the hammock cranes
I made a little tool to make sure that the hammock cranes can be placed easily and superglued in exactly vertical position. The next pictures show how I used that tool:
A really tiny amount of superglue is sufficient to fix the hammock cranes.
Bernd
#125 Posted : 18 April 2013 23:20:51
Around the forecastle I made little slits to provide a stable support for the U-frames
Last step is to push the wire through the holes in the hammock cranes. This is most difficult on the poop deck, where the holes are not in a straight line
If the wire is secured with a little superglue, the whole construction becomes reasonably stable and robust
Bernd
#126 Posted : 18 April 2013 23:21:59
With the hammock nets I tried the following.
I took the precise measures and cut slightly larger holes into a piece of cardboard on which I glued the net
A little bit inside the border I glued a 0,15mm black thread with thinned PVA glue
When everything is dry, one can cut the nets from the frame and obtain a net with a clean border.
Admittedly, this is a fairly complicated treatment, but It is now much easier to sew these nets to the frames. These hands belong to my beloved wife who showed me how to do this:
Thats all for today,
kind regards
Bernd
#127 Posted : 18 April 2013 23:30:41
Absolutely stunning!!BigGrin BigGrin BigGrin
#128 Posted : 18 April 2013 23:34:05
Now those hands definately belong to an artist Bernd...BigGrin . stunning work.... Cool Cool
petpole
#129 Posted : 18 April 2013 23:37:24
Loving all the detail Bernd, your doing a tremendous job there.
Keep up the good work.
Drool Drool Drool Drool
Jesus-Belzheim
#130 Posted : 19 April 2013 07:49:47
Your build looks fantastic Bernd Love
Kind regards
Peter BigGrin
HMS Victory 1:84 DeA
#131 Posted : 19 April 2013 07:59:01
Bernd, OUTSTANDING!!!!!!!!BigGrin Drool all the best Mike
DaDokta
#132 Posted : 19 April 2013 08:05:25
Fantastic!
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
der Gohfelder
#133 Posted : 19 April 2013 08:26:21
Hi Bernd!
Nice work, very clean and absoltly stunning!
Regards, (also) BerndBigGrin
#134 Posted : 19 April 2013 09:02:15
WOW really stunning work there Bernd
#135 Posted : 19 April 2013 11:35:53
Awesome work Bernd..A delight to see... Love ThumpUp
#136 Posted : 19 April 2013 19:17:00
Love Wot a bril job wow Love Rgds Martyn
Bernd
#137 Posted : 19 April 2013 21:47:36
Hi there!
Here is the bow grating:
Before inserting the bowsprit I added a thin wooden strip to its base to have it sit a little steeper in its socket, leaving enough space for the crown of the figurehead.
When binding the gammons of the bowsprit I followed this illustration, which I found in an old book
It is very difficult to see this in a photo, as it is quite dark there
Then I decided to attach the figurehead right away, although this step comes much later in the magazine. Painting the figurehead was welcome distraction from the boring work of binding the deadeyes to the shrouds.
I found it rather difficult to attach the figurehead, I had to reshape the strips on the sides of the stern post for a better fit.
Nevertheless, the figurehead is a little too large for the scale of the model (which does not really bother me). As a consequence, the base looks a little bit misplaced, but otherwise it would have covered one of the holes in the stern post. Probably, I'll fill in some wood between the "legs" of the figurehead base later.
Greetings from Austria,
Bernd
Bernd
#138 Posted : 19 April 2013 22:13:17
After attaching all the deadeyes I started the tedious work of tensioning the shrouds,
adding the futtock staves, and catharpins,
and attaching the futtock shrouds to the futtock staves
Bernd
#139 Posted : 19 April 2013 22:26:27
Here are some impressions of the ratlines. I followed the method proposed in the magazine and official build diary
For me, it was impossible to add ratlines where the shrouds were soaked with superglue (better to use PVA glue to secure the deadeyes). I just omitted these ratlines and hope that nobody will notice Blushing
Best regards,
Bernd
Bernd
#140 Posted : 19 April 2013 22:43:55
When rigging stay and preventer, I didn't just tie a knot about the masttop, but rather followed a procedure found in the literature:
This is the upper end of the stay, with a loop and a "mouse"
and this is how it is used:
Everything else is just as described in the magazine. Therefore I show these images without comment:
That's all for today!
Greetings from Austria BigGrin
Bernd
Guest (13)
14 Pages «<56789>»
This page was generated in 0.195 seconds.
