40 Pages «<3031323334>»
MWG build diary of HMS Sovereign of the Seas Options
SandyM
#621 Posted : 28 April 2013 15:05:57
Hi Nigel,
Tried Cornwall model boats didn't have oak that thin. I love working with oak and will be making a display cabinet for SOTS with it and Irish granite.
Like wise I will be shortening the overhang when the bits arrive. Have a look at where the side gallery's end I believe they are also high in relation to the gun port. That's based on the mounting slots but will have to wait and see. I am expecting to remake the ginger beard as I am not planning in raising the proop deck.
Sandy
Various balsa aircraft both rubber powered and RC
Billing Jyland
Billing Wasa
Billing Dutch Royal Barge (gold medal winner Germany 1975)
Scratch built HMS Victory using HMSO plans hull size 26"
Scratch built Yamato Hull size 8'8"
De Pardo HMS Bounty
Current build Sovereign of the Seas
#622 Posted : 28 April 2013 15:14:31
SandyM wrote:
Hi Nigel,
Sandy
Hi Sandy you are on my build diary, could you transfer your gereral comments with Nigel to another topic pleaseBlink Huh Regards mike
SandyM
#623 Posted : 28 April 2013 15:36:53
Sorry mike
Billing Jyland
Billing Wasa
De Pardo HMS Bounty
NMBROOK
#624 Posted : 28 April 2013 15:51:46
Yes Mike I will have a go I am pretty useless with computers especially as i have had to just buy a new laptop I hate windows 8.Now going to try and find camera box with disc etc ,might be gone a whileLOL LOL LOL
I apologise if we were hijacking your thread.
Regards Nigel
#625 Posted : 28 April 2013 16:17:06
NMBROOK wrote:
Now this is getting REALLY interesting,do we agree that the tiller enters the rudder outside the hull?The one thing that throws me is the height of the gilded head on the rudder which would be higher than the tiller as shown in the portrait.Here is a list of my mods so far to give you something to mull over;
1/Rear two sections filled with epoxy and microballoons below the waterline.This enabled me to reprofile the rear of the hull to a proper round tuck.
2/Hull is planked in hard maple below the main wales.All planking above wales is boxwood.I have done the main wales in walnut.I agree with you Sandy and Mike,mahogany does look right on models the grain is far too large.I was tempted to use ebony for the black sections but upon research I deemed it far too much hassle to work with.I have obtained some more boxwood strips to plank the decks.As you may have gathered the only paint used will black and gold apart from the George crosses inside the gunport lids.All planking is 4mm wide
3/I have altered the shear of the wales as I deemed them wrong as represented,not correct shipbuilding practice to have have a main wale chopped through completely removing its strength.I know this is shown on the payne engraving but on a high res image of the portrait you can see the upper main wale just clip the bottom of the last gunports.
There are more mods in the planningBigGrin BigGrin
Regards Nigel
Hi NMBROOK,
You certainly seem to have made a lot of changes. Do you have your own build diary, i could not find one. maybee you could post some pics so we can get a better idea of what you are on about and a link to the pic you have based all these changes on. It would be better than cluttering up Mikes build BigGrin
#626 Posted : 28 April 2013 16:46:16
PLANKING
I have only fitted 6 planks each side of the gardboard planks and including the Keel as you will see in my build Diary. now I am fitting the middle planks (Port and Starboard) after this I will put in frames for the gun ports before I plank the whole ship.
Through the photos you will see from the soaking stage, fitting the wet plank to the hull to allow it to dry out, then the final fitting with aliphatic glue, at the same time you will see the fillets I have fitted behind the planks as required:-
NMBROOK
#627 Posted : 28 April 2013 16:51:08
Mike could not find camera disc emailed photos from iphone to laptop gonna have a go now at starting build log.
Regards Nigel
#628 Posted : 28 April 2013 16:55:02
PLANKING
At this point I put a spacer of a short section of planking just under the side Gallery:-
#629 Posted : 28 April 2013 16:57:50
PLANKING
Then the fillet was removed as you can see:-
#630 Posted : 28 April 2013 17:05:17
PLANKING
The blue pointer shows the fillets behind the plank.
Thats all for now thank you for looking inBigGrin Kind regards Mike
Admiral Anti Spiral
#631 Posted : 28 April 2013 17:48:48
Looking great there mike! BigGrin
Processing - Progressing
Previous builds: HMS Victory
#632 Posted : 28 April 2013 18:06:42
Thanks Admiral, for the nice commentBigGrin Kind regards Mike
#633 Posted : 28 April 2013 19:48:02
BigGrin Hi Mike
top work as usual
#634 Posted : 28 April 2013 20:03:34
BigGrin Hi Mike
top work as usual
Hi Andy, thank you for your encouragementBigGrin cheers Mike
#635 Posted : 28 April 2013 23:08:56
Love the way you explain the task at hand Mike, the reasons for doing the mods and how to carry them out.... Really coming along and enjoying your build.... BigGrin BigGrin
#636 Posted : 29 April 2013 00:27:01
Hi Alan, thank you for the nice commentsBigGrin Kind regards Mike
SandyM
#637 Posted : 29 April 2013 00:27:59
Hi Mike,
She's looking realy good. Wish I had not used the bambo. Keep the photos coming.
Sandy
Billing Jyland
Billing Wasa
De Pardo HMS Bounty
#638 Posted : 29 April 2013 08:49:14
SandyM wrote:
Hi Mike,
Sandy
Hi Sandy, thank you, I willBigGrin Kind regards Mike
#639 Posted : 29 April 2013 09:57:33
Good job. good tutorial, thanks Mike.
#640 Posted : 29 April 2013 13:43:39
Looking great Mike and some handy tips you are sharingCool
Guest (8)
This page was generated in 3.566 seconds.
