plank finish Options
stujue
#1 Posted : 28 April 2013 21:03:27
Im just about to start the upper levels of planks. Can anyone say if the internal surface of the bamboo planks
will be the finished surface or does the internal have a second layer of planks the same as the outside will have.
Cheers
Stu
Cheers Stu
#2 Posted : 28 April 2013 21:09:12
Internals of bulwarks where can be seen will be planked on the inside..
#3 Posted : 28 April 2013 21:10:11
Cheers
Stu
Hi Stu,it is usual to have an internal planking which sits the other side of the rib. I hope that helps Kind regards Mike
stujue
#4 Posted : 28 April 2013 21:30:54
thanks Mr T / MWG.
Cheers Stu
This page was generated in 0.305 seconds.
