Hi Willz, simply amazing... very well done... How many more do you have to do????..  Think you will be at it for months.... Regards Alan
Thanks for the comments much appreciated. As for the balustrades Alan just another 137 on the rear and then more on the sides at a later stage. Got a bit fed up so broke off to do half a strongman, as you can see only half done but won`t be going overboard with detail willz attached the following image(s):
oops !!!! not so strong strongman willz attached the following image(s):
W.I.P. new strongman willz attached the following image(s):
Hi Willz, the second one looks much better  the first one broke because it was not ment to be. Fabulous work Cheers Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
 Rank: Pro   Groups: Joined: 04/05/2012 Posts: 362 Points: 1,089
Your strongman looks good Wilz
Very nice indeed Willz,  .. At least this time he is not legless... Regards Alan
Must agree with Mike and Alan, the second one wins. I'm amazed at your attention to detail. Beautiful work. Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
That is outstanding work
Joined: 20/10/2010 Posts: 511 Points: 1,459 Location: Loughborough
 Rank: Pro Groups: Registered
Joined: 31/12/2011 Posts: 123 Points: 369 Location: Graz, Austria
Amazing!
Joined: 22/07/2012 Posts: 69 Points: 144 Location: Belgium
Keep them pictures comming Will. Enjoying your detail so much, good job! how does that saying go again for better luck? Oh yes: "Break a leg!"
Genius at work, you are on another level Steve
Love watching this build although id does make me feel a bit like a bigginer  fantastic work!!! “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
thanks for all the kind comments lads, big repair going on with the lower windows, as you can see its not all plain sailing (pardon the pun) willz attached the following image(s):
Sorry to see the damage there Willz, you were going so well...  .. How did you manage to do that???? Am sure you will get her repaired and looking her best.... Good luck with it, will be following... Regards Alan
Gandale wrote:Sorry to see the damage there Willz, you were going so well...  .. How did you manage to do that???? Am sure you will get her repaired and looking her best.... Good luck with it, will be following... Regards Alan always getting our windows put through round here Alan
As I continue with my scratch stern my thoughts have been on how to make the band that splashes across the top, thought about making it out of laminated strips or just carving it out of one piece, anyhow decided to carve, still work in progress, slowly carving it down to scale, at the mo its too bulky, have to slowly chip away till I get there otherwise it will snap like the twig that it is willz attached the following image(s):
Absolutely stunning  Brilliant work Willz! Kind Regards Nigel
Guest (28)
