162 Pages «<3839404142>»
#781 Posted : 03 May 2013 23:30:06
NMBROOK wrote:
Looking good Alan.You may have noticed already but just check the gunport upper deck third from stern looks a little twisted on the photo.If you chock the hull level fore aft and side to side you can double check your bottom cills are horizontal using a short spirit level.When you come to sizing the ports I recommend sticking abrasive paper to some scrap wood.If you use say 10mm square strip and glue the abrasive paper you can rest the smooth side against one finished edge whilst sanding the adjacent edge,this helps a great deal in keeping the ports square.I used to use needle files but they soon loose their edge doing gunports unless you use permagrit ones.
Kind Regards
Nigel
Thanks Nigel, especially for your eagle eye..... that port was about .5mm out on the right side which is why it looked a little twisted..... corrected now... BigGrin .. Am now in the process of making a cradle for the old girl to hold her steady and level on all planes... As I said, my intention will be to double check each port in turn just before I start cutting and will also look to use your method of using a square strip with sandpaper glued to one side.... It's always the simplest methods that turn out to be the best..... Thanks again for pointing out the flaw....
On the subject of the hull profile, I have been checking my hull and also looked back through the pictures I have posted along the hull profile and for the life of me I cannot see the dip you are referring to... maybe I have been lucky I don't know but am sure we will find out for definate when it comes to applying the lower whales....Cool Cool
Thanks again...
NMBROOK
#782 Posted : 04 May 2013 00:21:46
No problem Alan sometimes it takes a fresh pair of eyes.I find with something like this you need to walk away then comeback later and most importantly stand well back and cast an eye over everything.When you are marking them out you are up close with the model and especially with the hull shape,discrepences dont stand out.Another trick is to look along the side of the hull from both bow and stern and check your gunports follow a smooth line.With the most accurate marking in the world you may find you have to move a port up or down fractions of a mm.
As regards the hull check stujue's post on the thread he's posted a photo that clearly shows what i mean.
Kind regards
Nigel
#783 Posted : 04 May 2013 00:33:08
Kind regards
Nigel
Hi Nigel, completely agree with your comments and it will be advice I will be following... The cutting of the ports are I believe a crucial part of the build, get this wrong and the whole build will be spoilt.... Cool Cool
As for the dip in the stern, is this what you are referring to????
Admiral Anti Spiral
#784 Posted : 04 May 2013 00:43:23
Hi Alan, having a closer look at the gun ports you've drawn, it might just be me, but i think the top deck gun port between frame 20 and 21 is a little off? should it not be right up against frame 20?
Processing - Progressing
Previous builds: HMS Victory
NMBROOK
#785 Posted : 04 May 2013 00:52:39
No mate if you look at the hull from above with the hull upside down look at the sides of the hull just before the stern.The dip you are showing is as it should be.
Kind regards Nigel
NMBROOK
#786 Posted : 04 May 2013 01:01:58
Hope this helps Alan
Kind Regards
Nigel
NMBROOK attached the following image(s):
#787 Posted : 04 May 2013 01:19:49
Hi Admiral, you are spot on and a huge thank you for pointing that out... not only was the port twisted slightly but it is completely in the wrong position.... Port has now been rubbed out and will be done again tomorrow.... Just goes to show the benefits of having other eyes look over your work.... BigGrin BigGrin . You're a star....Cool Cool
#788 Posted : 04 May 2013 01:28:58
Hi Nigel, yes your pic helps a lot..... same view of my build....
NMBROOK
#789 Posted : 04 May 2013 01:49:27
Your portside looks pretty good but the starboard looks like it dips in then theres a little hump just before the stern.If you place a ruler where i did you will see what i mean.This last 200mm wants to be straight.
Kind Regards Nigel
#790 Posted : 04 May 2013 22:28:06
Kind Regards Nigel
Thanks Nigel, can now see what you are referring to... Will rectify this when I come to planking the second layer.... Cool Cool .. Thanks again....
NMBROOK
#791 Posted : 04 May 2013 22:33:43
My pleasure Alan,glad to be of helpBigGrin
Kind regards Nigel
#792 Posted : 04 May 2013 22:37:59
Well have done quite a bit of experimentation in order to find the best method of marking and cutting out these ports and finally came up with a method that suits me best... First thing I did was to make up a port jig from a piece of 12x12mm walnut glued onto a 12x10mm piece of pinewood. Using serious glue, glued a small level onto the pinewood... Blink Blink
#793 Posted : 04 May 2013 22:45:52
Cut a piece of 12x10mm pinewood and to one of the 12mm sides glued some fine grade sandpaper....Blink Blink .. This helps to tidy up the port edges and help to ensure the ports are square.... BigGrin
NMBROOK
#794 Posted : 04 May 2013 22:46:32
Now that is a seriously good idea Alan.I have never seen nor read of this
but when you think of it,it makes so much sense.Absolutely brilliant,I for one will be pinching this oneBigGrin BigGrin
Kind Regards Nigel
NMBROOK
#795 Posted : 04 May 2013 22:50:24
Just seen your sanding stick,my only critiscism is if you are sanding the ports out to 12mm,how does the twelve mm side fit in as you are opening it up?
Kind Regards Nigel
#796 Posted : 04 May 2013 22:57:37
Next came the problem of ensuring the hull was secure and level on all planes. Build myself a cradle for the ship to sit in and leveled it off...Blink Blink
#797 Posted : 04 May 2013 23:03:15
Kind Regards Nigel
You are welcome to pinch the idea Nigel, nice to know I have been able to help you in return... It has many uses as you will see during the explanation of my process... Cool Cool .. As for the sanding stick, it does fit as will become clear... ports are 13x12 and stick is 12x10... Cool
#798 Posted : 04 May 2013 23:06:42
With everything level and secure marked out the port roughly where they are to be locaated. Double checking all measurements I then got down to ensuring the port was square and level... Blink Blink .. Did this by first marking in the uprights using a set square...Cool
#799 Posted : 04 May 2013 23:10:39
Using the port jig on its side then marked up the top and bottom of the port again double checking all measurements... Cool
#800 Posted : 04 May 2013 23:13:13
Once happy, got down to the business of actually cutting the port out... Using my dremel with flexi drive and router bit carefully cut the port out ensuring I stayed inside the cut lines.. Cool
Guest (11)
This page was generated in 1.113 seconds.
