162 Pages «<3940414243>»
#801 Posted : 04 May 2013 23:28:56
Started to tidy up the sides of the ports with a sharp knife again ensuring I did not encroach on the cut lines finally finishing off with the the fine sanding stick.... Cool .. It is important to sand the sides of the port in the right sequence, the port is 13mm wide and the sanding stick is 12mm so you must sand the upper and lower edges first to the marked lines, you should then be able to turn the stick 90 degrees to then sand the sides.... Cool Cool .. Finally using the port jig, the jig being 12x12mm should slide snuggly into the port and the level will also be confirmed.... Cool Cool
#802 Posted : 04 May 2013 23:33:00
Have completed 7 ports and felt that was enough for tonight... Any minor adjustments can be made now when it comes to lining the ports....
Happy building all.... BigGrin BigGrin
#803 Posted : 04 May 2013 23:56:01
BigGrin Looking good AlanCool
#804 Posted : 05 May 2013 00:09:15
There, See!
Told you you could do it!BigGrin That's coming on brilliantly, the only thing I'd caution (but it might be just the photo) is to watch you don't dremel too close to the lines, those things can spin off course in half a second!!
Very well done Alan.
#805 Posted : 05 May 2013 00:16:47
Plymouth57 wrote:
There, See!
Thanks for the very nice comment Robin.... BigGrin BigGrin .. I know exactly what you are saying and I did do a number of practice cut outs on scrap planks before letting the dremel anywhere near the build.... BigGrin BigGrin .. You are of course correct, if you don't keep a firm grip of the tool or try to cut away too much at once then yes, it can spin out of control..... BigGrin ..Would recommend builders carry out practice cuts first if using this tool..... Good advice Robin and thanks again.... BigGrin BigGrin
NMBROOK
#806 Posted : 05 May 2013 00:36:18
Very impressive Alan you have obviously thought the process through very thoroughly.I stand corrected with the sanding stick,your one step ahead of me.
Kind Regards Nigel
#807 Posted : 05 May 2013 00:48:18
Kind Regards Nigel
Thank you for the very nice comment Nigel, I really appreciate it....Cool Cool .. As this is my first build I try to think the processes through before committing to the build, read a lot of diaries of other builds to see how things are done....Blink Blink .. So far am happy to say things appear to be working out for me but no doubt something will get me somewhere down the line, hope not but am prepared for it.... BigGrin BigGrin .. Thanks again....
Best regards
#808 Posted : 05 May 2013 08:31:58
Woot Brilliant Brilliant Brilliant Well Done Alan Love this build Love Rgd Martyn
#809 Posted : 05 May 2013 10:04:30
Hi Alan,BigGrin
Some stunning work there Alan and some innovative ideas for marking and cutting the gun ports.
WTG Cool Drool
#810 Posted : 05 May 2013 10:13:43
Hi Alan, what can I say, FABULOUS work and GREAT methodoligyBigGrin I love your work!!!!! Kind regards Mike
#811 Posted : 05 May 2013 10:27:29
Thanks Andy, always appreciate your comments... BigGrin BigGrin
#812 Posted : 05 May 2013 10:30:09
Thanks Martyn, appreciate your very supportive comments, glad you like the build... BigGrin BigGrin .. Hope you will find some of it useful for your own build.... Cool Cool
#813 Posted : 05 May 2013 10:31:47
delboy271155 wrote:
Hi Alan,BigGrin
WTG Cool Drool
Appreciate your comments Derek, hope you find the ideas useful... BigGrin BigGrin
#814 Posted : 05 May 2013 10:37:10
Hi Mike, a huge thank you for the very warm and supportive feedback... Cool Cool .. Support from members of this forum has been nothing short of inspirational leaving me feeling rather humbled... BigGrin BigGrin ..Thanks again...
der Gohfelder
#815 Posted : 05 May 2013 10:37:56
Hi Alan!
Like always a very nice job you made! I hope you don´t get bloody fingers BigGrin
Regards, Bernd
#816 Posted : 05 May 2013 21:22:07
der Gohfelder wrote:
Hi Alan!
Regards, Bernd
Thank you Bernd, always nice to hear from you... BigGrin BigGrin .. Still cutting gun ports and happy to say I still have all of my fingers intact.... LOL LOL ..
Admiral Anti Spiral
#817 Posted : 05 May 2013 22:50:25
Coming along really great alan, looks brilliant, keep it up!
Processing - Progressing
Previous builds: HMS Victory
#818 Posted : 05 May 2013 22:52:58
Thanks Admiral, cutting ports is a slow process but am enjoying it....Cool Cool
#819 Posted : 06 May 2013 22:41:25
Finally finished cutting out the ports on one side.. Blink Blink .. Had to lower 2 ports on the top deck which was a pain Mad Mad . My own fault and should have been paying more attention.... embarassed to say but I used the wrong side of the rule (the inches side) to get the position of the port bases Blushing Blushing Blushing ... Any corrections to the ports that may be necessary can now be done when the second planking layer is being done and when they are being lined..... Cool Cool
#820 Posted : 06 May 2013 22:46:14
BigGrin Hi Alan
Looking good there, as for the mistake with the ruler I think at some time or other we have all done it, plus no real harm done as you say all can be rectified with the secondary planking hiding anything
Guest (10)
This page was generated in 1.484 seconds.
