Started to tidy up the sides of the ports with a sharp knife again ensuring I did not encroach on the cut lines finally finishing off with the the fine sanding stick....  .. It is important to sand the sides of the port in the right sequence, the port is 13mm wide and the sanding stick is 12mm so you must sand the upper and lower edges first to the marked lines, you should then be able to turn the stick 90 degrees to then sand the sides....  .. Finally using the port jig, the jig being 12x12mm should slide snuggly into the port and the level will also be confirmed.... Gandale attached the following image(s):
Have completed 7 ports and felt that was enough for tonight... Any minor adjustments can be made now when it comes to lining the ports.... Happy building all.... Regards Alan Gandale attached the following image(s):
 Looking good Alan Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
There, See! Told you you could do it!  That's coming on brilliantly, the only thing I'd caution (but it might be just the photo) is to watch you don't dremel too close to the lines, those things can spin off course in half a second!! Very well done Alan. Robin First wooden ship: The Grimsby 12 Gun 'Frigate' by Constructo Second: Bounty DelPrado Part Works Third: HMS Victory DelPrado Part Works 1/100 scale Diorama of the Battle of the Brandywine from the American Revolutionary War Diorama of the Battle of New Falkland (unfinished sci-fi), Great War Centenary Diorama of the Messines Ridge Assault Index for the Victory diary is on page 1
Plymouth57 wrote:There, See! Told you you could do it!  That's coming on brilliantly, the only thing I'd caution (but it might be just the photo) is to watch you don't dremel too close to the lines, those things can spin off course in half a second!! Very well done Alan. Robin Thanks for the very nice comment Robin....  .. I know exactly what you are saying and I did do a number of practice cut outs on scrap planks before letting the dremel anywhere near the build....  .. You are of course correct, if you don't keep a firm grip of the tool or try to cut away too much at once then yes, it can spin out of control.....  ..Would recommend builders carry out practice cuts first if using this tool..... Good advice Robin and thanks again.... Regards Alan
Very impressive Alan you have obviously thought the process through very thoroughly.I stand corrected with the sanding stick,your one step ahead of me. Kind Regards Nigel
NMBROOK wrote:Very impressive Alan you have obviously thought the process through very thoroughly.I stand corrected with the sanding stick,your one step ahead of me. Kind Regards Nigel Thank you for the very nice comment Nigel, I really appreciate it....  .. As this is my first build I try to think the processes through before committing to the build, read a lot of diaries of other builds to see how things are done....  .. So far am happy to say things appear to be working out for me but no doubt something will get me somewhere down the line, hope not but am prepared for it....  .. Thanks again.... Best regards Alan
 Brilliant Brilliant Brilliant Well Done Alan Love this build  Rgd Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
Hi Alan, Some stunning work there Alan and some innovative ideas for marking and cutting the gun ports. WTG Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Hi Alan, what can I say, FABULOUS work and GREAT methodoligy  I love your work!!!!! Kind regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
arpurchase wrote: Looking good Alan Thanks Andy, always appreciate your comments... Regards Alan
Martyn Ingram wrote: Brilliant Brilliant Brilliant Well Done Alan Love this build  Rgd Martyn Thanks Martyn, appreciate your very supportive comments, glad you like the build...  .. Hope you will find some of it useful for your own build.... Regards Alan
delboy271155 wrote:Hi Alan, Some stunning work there Alan and some innovative ideas for marking and cutting the gun ports. WTG Regards delboy271155 (Derek) Appreciate your comments Derek, hope you find the ideas useful... Regards Alan
MWG wrote:Hi Alan, what can I say, FABULOUS work and GREAT methodoligy  I love your work!!!!! Kind regards Mike Hi Mike, a huge thank you for the very warm and supportive feedback...  .. Support from members of this forum has been nothing short of inspirational leaving me feeling rather humbled...  ..Thanks again... Regards Alan
 Rank: Vice-Master        Groups: Registered
Joined: 17/11/2012 Posts: 863 Points: 2,608 Location: Gohfeld (Germany)
Hi Alan! Like always a very nice job you made! I hope you don´t get bloody fingers Regards, Bernd
der Gohfelder wrote:Hi Alan! Like always a very nice job you made! I hope you don´t get bloody fingers Regards, Bernd Thank you Bernd, always nice to hear from you...  .. Still cutting gun ports and happy to say I still have all of my fingers intact....  .. Regards Alan
Joined: 24/09/2012 Posts: 491 Points: 1,452 Location: London
Coming along really great alan, looks brilliant, keep it up! Processing - Progressing
Previous builds: HMS Victory Current build: HMS Sovereign of the seas
Admiral Anti Spiral wrote:Coming along really great alan, looks brilliant, keep it up! Thanks Admiral, cutting ports is a slow process but am enjoying it.... Regards Alan
Finally finished cutting out the ports on one side..  .. Had to lower 2 ports on the top deck which was a pain  . My own fault and should have been paying more attention.... embarassed to say but I used the wrong side of the rule (the inches side) to get the position of the port bases  ... Any corrections to the ports that may be necessary can now be done when the second planking layer is being done and when they are being lined..... Regards Alan Gandale attached the following image(s):
 Hi Alan Looking good there, as for the mistake with the ruler I think at some time or other we have all done it, plus no real harm done as you say all can be rectified with the secondary planking hiding anything regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Guest (19)
