13 Pages <12345>»
Hachette's 1:16 Tiger Tank Options
#41 Posted : 11 May 2013 13:52:40
Hi Wilfy, Mike and Andy, thanks for looking in and your comments.
Wilfy, I got my barrel and muzzle brake from Welsh Dragon, they are by Schumo. A friend of mine works at a precision machine shop and cut and turned them down to fit the kit. Most of my upgrades come from Welsh Dragon models or Tankzone. They are great and have everything you could ever need to up grade this kit.BigGrin BigGrin
Hi Mike, I will post as many pics as I can to help anyone else building this, I know there are hundreds of mods that can be done to this kit, but I will only be doing the ones I think I need. If there are any you want to do that I haven't then please ask and I will advise the best I can.BigGrin BigGrin
Andy, I know what you mean!!LOL LOL Its a shame that they didn't do more research on the Tiger to make this a superb kit with out bashing it. And it wouldn't have taken much to get it right either!!BigGrin BigGrin
#42 Posted : 11 May 2013 21:33:35
STOP!!!!! Its Dremel Time!!!!
The catch basket for the empty shells is way over sized, and reminded me of the old Butler sinks!!LOL LOL LOL
So I cut 10mm out of it and stuck it back together!!! Bit of the old glen miller and hey presto, its the right size!!!LOL LOL LOL BigGrin
#43 Posted : 11 May 2013 21:56:27
Loving watching this come together Nem Cool
SennaMentalMe
#44 Posted : 11 May 2013 22:29:21
Nemesis wrote:
.... Bit of the old glen miller and hey presto, its the right size!!!LOL LOL LOL BigGrin
Ooooh .... I luurrvvvv a bit of the old Glen Miller!! Love Love
"Pennsylvania six-five-oh-oh-oh ....."!! Love Love
"In the mood ... baa dah ... baadappa da daah ... in the mood ... baa dah ....."!! Love Love
"There'll be bloooo birds over, the White Cliffs of Do ....." Oh no ... that's Vera Lynn - HaHa! LOL LOL LOL Blink Flapper BigGrin
Nice work Daran!! CoolThumpUp
#45 Posted : 11 May 2013 23:11:27
Hi Mr T and Kev. Thanks for looking in and your comments!BigGrin BigGrin
Oh and Kev, don't give up the day job!!!!Flapper Flapper LOL LOL BigGrin
Breech block is done, I have modeled it in the firing position. Bit more filler, and then on with the sanding and detailing.BigGrin
SennaMentalMe
#46 Posted : 12 May 2013 00:16:16
Shame you used the word 'filler' this time Daran, I was enjoying my bit of Glenn Miller!! LOL LOL Flapper Flapper BigGrin
Nice job on the breech block mate - a vast improvement on the kit part!! CoolThumpUp
#47 Posted : 12 May 2013 00:38:21
Hi Kev and thanks for the comments!!BigGrin BigGrin
Well whatever I did with the breech, it couldn't have looked any worse!!!!LOL LOL LOL LOL BigGrin
#48 Posted : 12 May 2013 01:22:11
BigGrin My kingdom ,my kingdom for a breach ah beggar its closed time to dieLOL Blink LOL Cool
Nice work Nem
#49 Posted : 12 May 2013 01:24:55
Hi Andy, and thanks for the comments!! I did try one with it open, but I didn't like it. Looks better closed!!LOL BigGrin
#50 Posted : 12 May 2013 10:57:09
Enjoying you eye for detail - some nicely done improvement
J
#51 Posted : 12 May 2013 13:40:53
Hi Jase, thanks for looking in and your comments.BigGrin
#52 Posted : 12 May 2013 17:13:16
Breech with a coat of primer. Very pleased so far, just some fine details to do and a bit of tidying up.
#53 Posted : 12 May 2013 17:18:58
Started the mods on the rear hatch.
Trimmed down and sanded.
Before and after.
Wilfy the Sea Dog
#54 Posted : 15 May 2013 00:17:58
Looking great Nem,
Breech looks fab, can you give us a bit more detail on how you did that?
Looks far better & easier than the ideas I.ve been messing with.
Thanks
Wilfy
#55 Posted : 15 May 2013 01:50:43
Hi Wilfy, thanks for looking in and your comments!BigGrin BigGrin
For the breech block I did this:-
1. Cut some plasticard to block off the three sides of the inner breech. I made them taller than the breech to make them easier to stick in place, and its easy to trim them level.Make sure they are a perfect fit so there are no gaps. Once dry, trim them to the level of the top of the breech.
2. Now cut a small piece to make the curve in the top of the breech block. If you warm it and form it round a brush handle its easier to fit. Its trial and error on this, so make it to long and then trim it till it looks similar to mine. Once your happy with the shape, glue it in place.
3. Cut another piece the same as the back of the breech block and close in the front. Again make sure its a perfect fit. dont worry about the shape as yet, its easier to do last.
4. The front of the loading breech is all one piece. Cut a square just big enough that it over hangs the front and top, and butts up tight with no gaps against the main breech. Once you happy with the fit glue one side only to the middle of the curve, and then using a cylinder the same bore, insert it so that it pushes the card into the keyhole shape. When dry using a thick needle, apply the glue to the other side, you should be able to pull the card away enough to get the glue in. Than use the cylinder again to form the card to the keyhole shape.
5. Leave it to dry for a while and then trim the card to the shape of the Breech. Now you can shape the curve in the block. Cut out most of it with side cutters leaving a 'V' and then carefully finish the rest with a scalpel and fine round file.
Voila!! The five step breech block!!LOL LOL BigGrin
I hope that helps you, but if you get stuck let me know, and if you really get fed up and want to post it to me I will happily build it for you.BigGrin BigGrin BigGrin
DaranBigGrin
#56 Posted : 15 May 2013 16:54:11
Turret with base coat inside and out.
#57 Posted : 15 May 2013 17:00:41
Gun breech and catch basket with base coat.
SennaMentalMe
#58 Posted : 15 May 2013 18:07:47
Top quality work as always Daran - keep the updates coming mate, I'm enjoying watching this build develop!!CoolThumpUp
#59 Posted : 15 May 2013 19:19:54
BigGrin looks good daranCool
#60 Posted : 20 May 2013 19:47:24
Barrel, breech and mantlet completed, just some small fine tuning and weathering to do. The completed section is 38cm long!!!Blink LOL BigGrin
I did a dry run of the main turret components, its huge!!!Blink LOL BigGrin
Guest (16)
13 Pages <12345>»
This page was generated in 0.172 seconds.
