32 Pages «<1920212223>»
#401 Posted : 03 May 2013 19:59:52
BigGrin Hi Yaturo
Thank you for explaining the tool very interesting. You are very lucky to have the display case from DeAg Japan I don't think we will be getting that here in the UK
#402 Posted : 05 May 2013 13:04:40
all the supplied decks have now been made up and some more platforms added plus the rear hangar doors were added this concludes all that was supplied in issue 21. As always all comments/questions are welcome
Yutaro HONMA
#403 Posted : 07 May 2013 03:44:47
Hi Andy!LOL
Your building is very fine and beautiful as usual.LOL
By the way, there is something that is bothering me in your last picture (pic #1).Confused
DeAGOSTINI Japan announced that they had provided a wrong metal part(pic #2) in the parts set of issue 39 when they provided issue 93. A lot of Japanese builders had to remove the wrong part and re-attach a new metal part in the last stage.Cursing
They showed us the picture of a wrong part(pic #2) then. The part on your Akagi is marked in the pic #1.
The right part(pic #3) was provided in the parts set of the issue 100 that was a last issue.
I am worried if your part is more resemble to the wrong part than the right one.Confused
I guess you are close to the stage where antenna masts are attached. Although a mast is never located above the gun (pic#4), a right bow side mast is located on the gun in this model(pic#5).
Be careful.Cool
Best Regards,
Yutaro
#404 Posted : 07 May 2013 19:18:24
BigGrin Hi Yaturo
Yes I was aware about the missing projection at the end of the platform, im not sure if that part is to be reissued here though. As for the masts I had already noted that from one of your previous posts
#405 Posted : 07 May 2013 23:59:26
She's really coming together now Andy, looks beautiful....Drool Drool
Very well done..
bluedot0
#406 Posted : 08 May 2013 09:39:50
Hi Andy
She's looking in exceptionally fine shape, a wonderful job.....
Phil
You only live once, but if you work it right, once is enough.
Building - Bismarck, Akagi, Warspite, Gato, USS Enterprise (carrier) and D51
#407 Posted : 08 May 2013 21:14:41
BigGrin Hi Phil
#408 Posted : 12 May 2013 20:35:58
received pack 22 yesterday so iv been busy filing metal frames and uprights. The last two deck parts are included with lots of cast metal work to be fitted so some deburing was needed and be carefull with the instructions as its easy to get things the wrong way round if your not paying attention. At the moment it mostly spraying parts up after construction so a few pics on progress
#409 Posted : 13 May 2013 17:06:54
This months building is about done now, finished off the decks and added some more refuges. The first 4 supports for the rear deck are in place now with the bracing wires added just a little painting left to tidy things up.
#410 Posted : 13 May 2013 18:37:38
Hi Andy I admire your commitment to this modelBigGrin very good workBigGrin Kind regards Mike
Gaz
#411 Posted : 13 May 2013 18:44:59
Hi AndyBigGrin
Fabulous work. She really looking the partDrool
Gareth
#412 Posted : 13 May 2013 19:53:57
BigGrin Hi Mike and Gaz
#413 Posted : 13 May 2013 21:44:20
Looking great Andy.
Have you resolved your deck issue?
#414 Posted : 13 May 2013 22:56:19
BigGrin Hi Jase
I think I will be sticking the decks down it means I will lose the internals but as Yaturo says a lot of Japanese builders did this aswell and he hasn't moved the decks since he 1st built his and its now in a display case. Thanks for looking in and your comments
#415 Posted : 14 May 2013 00:05:35
Hi Andy, have to say I love following your work on ally your builds.... impressive standards you set for others to follow.... Drool Drool .. Looking great....
Dontshootme
#416 Posted : 14 May 2013 09:44:52
BigGrin Hi Jase
I'm thinking the same for when I get to mine,but because I know they should be there I will probably still build the lift workings etcBlink ...they may never see the light of day again but I will have the satisfaction that I didn't cut cornersLOL
#417 Posted : 14 May 2013 20:54:46
BigGrin Hi Rob
I think its the best solution, I did look at using metal press studs [ the type used in clothing] as a solution, what gave me the idea is they were used on my 'Panic' aircraft to hold the outer wing struts in position and I never lost one in 5 years of flying the brute.It would take some planning to do [like getting all the decks to line up] but it is feasible. Thanks for looking in and your comments and knowing there there even if you cant see them is still an achievement[ lots ofAngry Cursing Angry Cursing Mad Cursing fitting them all in as they get smaller]
#418 Posted : 14 May 2013 21:39:59
Well done Andy and looking great ThumpUp
#419 Posted : 14 May 2013 23:20:04
BigGrin Hi Tom and thanksCool
Yutaro HONMA
#420 Posted : 15 May 2013 03:47:41
Hi Andy!
I think there may be The Third Way for this issue. I made the central lift be a double floor structure. (pic #1) Although the reason I did it was different from a measure against the warped flight deck panels, this method might be applicable.
Making a removable lift floor, even if the panels were fixed, we can easily see the inside of the Akagi when it's necessary. (pic #2)
Best Regards,
Yutaro
Guest (12)
This page was generated in 0.490 seconds.
