28 Pages «<23456>»
Martyn's SOTS Build Options
#61 Posted : 13 May 2013 12:13:58
BigGrin Hi Derek thank's for the comment's BigGrin I have now cut the top hull and marked out the rib's as a reference point for the gun port's . Laugh Thank's for looking in Rgd MartynBigGrin
Martyn Ingram attached the following image(s):
#62 Posted : 13 May 2013 14:21:59
Looking good there Martyn. Keep it up.
#63 Posted : 13 May 2013 22:45:04
Like what I see Martyn, well done..... Cool Cool
#64 Posted : 15 May 2013 12:06:13
BigGrin Thank's Alan; Hans . Have re visited specsavers and now started marking out the gun port's. I have moved lower gun port between rib 16-20 it did look odd . Now look's like Gandale s and Mr T's build Rgd MartynBigGrin BigGrin
#65 Posted : 15 May 2013 13:07:51
coming on well martyn,well done.
#66 Posted : 15 May 2013 22:17:47
Very nicely done Martyn.... looking great... BigGrin BigGrin .. When it comes to cutting out those ports Specsavers may not be enough..... binoculars tied to your head may be the order of the day....Laugh Laugh Laugh ... Keep the good work going, will be following closely.... BigGrin BigGrin
#67 Posted : 16 May 2013 08:32:51
BigGrin Thank's Alan and Karl for the comment's . I now look like Mr Mago but I can see to cut the gun port'sLOL Keep on rocking Rgd Martyn
Admiral Anti Spiral
#68 Posted : 16 May 2013 20:29:18
comming along nicely Martyn, looks nice a smooth ready for the next layer :)
Processing - Progressing
Previous builds: HMS Victory
#69 Posted : 16 May 2013 20:34:53
Hi Martyn,
Looking seriously good Cool Cool
WTG matey.
#70 Posted : 17 May 2013 08:40:15
BigGrin Thank's all for the comment's . BigGrin I have started cutting out the gun port's Cursing The bamboo is a sod to cut Cursing Sneaky Scared I broke 4 scalpel blade'sCursing now use a small cutting discs and then file and sand to the pencil line's BigGrin Thank's for looking in Rgd Martyn
#71 Posted : 17 May 2013 19:59:06
Nice and neat Martyn and I know the bamboo is a pig to cut with a knife, hence the reason I used the dremel... Please wear safety glasses when using a cutting disc, the can shatter easily....Cool Cool .. Most of all, take your time and am sure you will get there... Well done again...
#72 Posted : 19 May 2013 08:58:46
BigGrin More cutting and sanding of the port's aprox 20-25 min's a port slow but funCool Thank's for looking in Rgd martyn BigGrin
#73 Posted : 19 May 2013 10:26:45
Very nice Martyn, 20-25 mins per port is time well spent, the results speak for themselves...BigGrin BigGrin .. Keep up the good work..
#74 Posted : 20 May 2013 16:02:43
Looking good there Martyn. Well done excellent job. This is not a race, so why not take your time, as Alan says the results speak for themselves.
Admiral Anti Spiral
#75 Posted : 22 May 2013 00:10:40
Lovely work here Martyn!
#76 Posted : 22 May 2013 12:45:16
ThumpUp Yippy all gun ports cut out on one side Blink Blink Now on to the next side Unsure Thanks for the comments BigGrin Rgd Martyn
NMBROOK
#77 Posted : 22 May 2013 13:20:52
Looking good Martin,very nice workBigGrin BigGrin
Nice to see a fellow archer,but then again if you shoot longbows you probably call me a cheat.LOL LOL I used to shoot compound.Won a couple of trophies but then had to give up due to a hiatus hernia.
Kind Regards Nigel
#78 Posted : 22 May 2013 13:30:17
Hi Martyn.
All looking goodBigGrin Kind regards Mike
#79 Posted : 22 May 2013 22:14:13
Your work is paying off Martyn, really nice job on those ports.... BigGrin BigGrin
#80 Posted : 23 May 2013 08:51:08
Good job on the ports there martyn.
28 Pages «<23456>»
This page was generated in 0.267 seconds.
