 Rank: Pro  Groups: Registered
Joined: 30/04/2013 Posts: 105 Points: 301 Location: Perth
Does the car come with sealed bearings in the wheels and on the drive shafts? Is that an After market part or an optional upgrade that can be done?
Front - two bearings within the wheel hub. Rear - Two bearings within the rear each hub carrier.
With Issue 20 you will receive an exploded view poster of all parts that make up the model.
