cockpit Options
shane1991
#1 Posted : 18 May 2013 04:10:01
Rank: Beginner Level 3
I see issue 19 is a helmet, in other pics you can see a steering wheel with hands. what else is involved in the cockpit of the car? does the helmet sit on a body or torso? i would think so, if there are hands there must be arms and so on ....
thanks guys
#2 Posted : 18 May 2013 09:36:59
BigGrin Hi Shane
If you look at the official build from page one ,there is a pic of the car body attached to the chassis and several of it removed, when you line up the cockpit there is too much stuff underneath to fit a compleat body figure on the model. So I suspect that the cockpit will have a flat floor that the helmet and stearing wheel will fit in but that's about it. Hope this helps
#3 Posted : 18 May 2013 10:20:07
Because of space limitations of an R/C car, compromises have to be made, there isn't a cockpit interior as such or full body driver.
On the static display body, the the middle upper body has a flat cockpit base which the helmet is secured to, the racing bodyshell also has a flat cockpit base. But for the racing bodyshell, a two piece helmet is provided which has a circular cutout at the rear, which locates onto the airfilter which is directed through a hole in the bodyshell and into the helmet.
As per the images below..
This page was generated in 1.246 seconds.
