Type of varnish to be used Options
KobusBeukes
#1 Posted : 19 May 2013 16:45:08
What varnish is recommended for the anchors and blocks for a natural look?Confused
Kobus
Current Build
#2 Posted : 19 May 2013 17:30:29
BigGrin Hi KB
Some people will use either a satin or matt varnish depending on the look you want but many will use Danish oil in a natural finish. One note on Danish Oil though as you add coats it will darken the finish but this can also help in getting the finish/colour you want. Hope this helps
AndyBigGrin
KobusBeukes
#3 Posted : 19 May 2013 20:18:16
Hi Andy,
Thanks a lot for the quick response. It's good to follow the builds as we, South Africa, has only started with the Sovereign of the Seas. This is also my first build and I enjoy it thouroughly.
Thanks
Kobus
Current Build
This page was generated in 0.154 seconds.
