13 Pages «<23456>»
Delboy271155 Sots Options
#61 Posted : 15 May 2013 20:21:20
petpole wrote:
Looking really nice there Derek. You got enough to be going on with then LOL LOL LOL LOL .
Keep up the good work.
Peter
BigGrin BigGrin BigGrin BigGrin
Thanks Peter,BigGrin
I`m working out a rota, working on deliveries and the biggest bug bear,
FUNDS, LOL LOL LOL LOL LOL
Thanks for looking in,
#62 Posted : 15 May 2013 20:24:09
Martyn Ingram wrote:
BigGrin Nice work Derek BigGrin Of to specsaver's you go LOL LOL Rgd Martyn
Hi Martyn,
Thanks for looking in and the nice comments, as for Specsavers our friendly Tesco stores do just a good job, are cheaper and you get club card points, RESULT LOL LOL LOL LOL LOL LOL
#63 Posted : 15 May 2013 21:02:08
Hi Derek, looks good, you are getting thereBigGrin Kind regards Mike
#64 Posted : 15 May 2013 21:11:45
Cheers Mike, BigGrin
I still class myself as a total newbie, but with the help of master builders like yourself, it is getting a lot easier and now more fun.
Many, many Thanks,
#65 Posted : 15 May 2013 23:11:06
Nicely done Derek, looks as if it will finish very nice indeed.... BigGrin BigGrin .. Onwards and upwards so keep posting..... BigGrin BigGrin
#66 Posted : 16 May 2013 19:25:46
Cheers Alan,BigGrin
Thanks for looking in, now it`s a choice of what to do first, having just received 4 issues of SOTS and 4 issues of Victory within the last 3 days.
Hey Ho time to toss a coin LOL LOL LOL LOL
#67 Posted : 19 May 2013 16:37:45
Hi All, BigGrin BigGrin
Update time, so in brief, having planked up to issue 28 and closed the lower hull,I went onto the gallery parts we received earlier.
To make sure the rear panel of the gallery was flush to the top of the frame, I clamped a piece of balsa on top and fitted the rear panel to butt up against it.
Pic 1:
Then it was a case of making sure the back panel was straight and clamping it in place, belt and braces here to make sure it didn`t move.
Pic 2:
The side panels were next (these pics also show dummy gun supports),clamping these also included some wedges under the clamp faces due to the curvature of the framework.
Pic 3+4:
Next a pic of the length of the dummy gun supports.
Pic 5:
Having had a short break from planking, yep, back to planking. The good bit was, no serious bends and/or twists required. Cool Cool.
So three layers of planks followed and here is the results to date.
Pic 6+7:
I am at this point saving the gun construction for a later date, with the intent of getting the planking finished and when I have regained my sanityMellow Mellow,I will have a bulk cannon building session.
That`s all folks, BigGrin BigGrin
#68 Posted : 19 May 2013 17:14:05
BigGrin Nice work Derek bril ThumpUp Rgd Martyn
#69 Posted : 19 May 2013 22:17:56
Very nice Derek, coming along very nicely... BigGrin BigGrin .. Soon have the upper hull planked....BigGrin BigGrin .. Keep up the good work...
#70 Posted : 19 May 2013 23:21:39
Hi Martyn,BigGrin
Thanks for looking in and the nice comments.
#71 Posted : 19 May 2013 23:31:23
Hi Alan, BigGrin BigGrin
Thanks for looking in, it`s nice to get to the point where the planking gets easier. Not so much bending and twisting.
I am actually looking forward to the sanding process to see how smooth I can get it and then the task of cutting the gun ports.
Planking has been a long exercise, but I have learnt a lot on how to look at a hull shape and this will hopefully help with future builds.
petpole
#72 Posted : 20 May 2013 01:47:16
Coming along nicely Derek.
Keep up the great work.
Peter
#73 Posted : 20 May 2013 20:32:32
Peter
Hi Peter,BigGrin
Thanks for looking in,got two days off now so a chance to get some serious work done. Only problem, I`ve only got parts up to 33, so will then be some time for the Victory.Cool Cool
#74 Posted : 20 May 2013 22:04:39
Hi Derek, get that sanding arm ready for lots of exercise.... BigGrin BigGrin ... From what I can see I think your hull will snad down very nicely and give you a good base for the next layer..... Cool Cool .. Look forward to seeing the progress.... BigGrin BigGrin
#75 Posted : 20 May 2013 22:20:59
Cheers Alan, BigGrin BigGrin
One question though on the subject of sanding. As this is the first time I`ve done this bit, do you sand and then find the low spots or do you give a leveling skim of filler and then sand?
This may seem like a silly question, but to the newbie it could make a lot of difference, as in time taken to finish this particular task.
#76 Posted : 20 May 2013 22:29:08
Never any silly questions Derek, it is how we gain knowledge.... LOL LOL ... I started off by using a fairly course grade sanding to get the basic smoothness, the bamboo will take quite a lot of sanding....Then I skimmed the whole hull with filler, mainly to fill in between the planks where the rounded edges of the bamboo are joined... You will soon see the little low and high spots as you move onto the finer sanding grades.....
Hope this helps...
#77 Posted : 20 May 2013 22:33:42
Hope this helps...
Thanks Alan,BigGrin
That makes a lot of sense, even to an oldish (LOL ) newbie like myself.
petpole
#78 Posted : 21 May 2013 01:18:56
Hi Derek another trick I find that works well os spraying a fine coat of undercoat then sanding down to a reasonable thickness then filling the low spots spaying again and then a final sand.
Hope this helps.
Great build so far.
Peter
Captain David
#79 Posted : 21 May 2013 09:50:49
It's coming along nicely, Derek. I hope my planking will be as good.
#80 Posted : 21 May 2013 10:30:28
Hope this helps.
Great build so far.
Peter
Another good tip, will get the planking to the top and make a judgement call when I see how it all looks when complete.
Got to wait for the next delivery to finish the very top bit of the planking though.Crying
13 Pages «<23456>»
This page was generated in 0.722 seconds.
