162 Pages «<4647484950>»
#941 Posted : 20 May 2013 22:51:39
Er...yes...looks really good Alan, but....are you sure she had THAT many oars!!LOL
She's looking gr8 m8!!
#942 Posted : 20 May 2013 22:58:45
LOL LOL LOL Just want to make sure she could row her way out of the dolldrums.....LOL LOL LOL .... Thanks Robin, appreciate the sense of humour.... I need it with this task I can tell you.....LOL LOL LOL
#943 Posted : 20 May 2013 23:04:12
Hi Alan, Top job it looks greatBigGrin Kind regards Mike
#944 Posted : 20 May 2013 23:06:50
Thanks Mike, any advice on recharging numbed brain cells.....LOL LOL LOL
NMBROOK
#945 Posted : 21 May 2013 09:37:24
She's going to look stunning AlanBigGrin BigGrin BigGrin .The only advice as regard the mind numbing is just walk away and do something else when you have had enough.I have finished treenailing one side and I am lining the gunports on that side for a break.Treenailing the lower hull is a MASSIVE job as I have found out,but the results are more than worth it.You will appreciate the results long after you have forgotten how long it took.
Kind Regards Nigel
Captain David
#946 Posted : 21 May 2013 09:47:56
I now want to do that! Lovely effect.
claret
#947 Posted : 21 May 2013 12:11:26
Hi Alan,
Porcupine of the Seas?
The second layer of planking looks exceptional and love the the treenailing, just might have a go at that mod!
Claret
Also working on:
SOTS.
Waiting in the wings:
finished:
007 Iconic DB5.
#948 Posted : 21 May 2013 12:34:37
hi alan, love the the treenailing, have you considered that there is the wales to fit????? will you be covering all that hard work up???? just a thought. great idea though. k.
#949 Posted : 21 May 2013 19:23:48
Kind Regards Nigel
Thanks for commenting Nigel.. Cool Cool .. It may be mind numbing stuff but truthfully am enjoying the experience.... Am doing exactly as you advise, doing a little and then walking away for a while... Am not to bothered as to how long the process will take.... just want it to look right....Cool Cool .. Thanks again..
#950 Posted : 21 May 2013 19:25:30
Happy you like it David, if you do carry out this task then take your time and you will get the results you are after....BigGrin BigGrin
#951 Posted : 21 May 2013 19:27:01
claret wrote:
Hi Alan,
Claret
Thanks Claret, appreciate your nice comments.... Have a go, it'll be worth it I'm sure.... BigGrin BigGrin
#952 Posted : 21 May 2013 19:33:37
Hi Karl, nice to hear from you and really appreciate your comments.... Cool Cool .. I have given thought to quite a few things on this process and you are of course correct about the wales.. I don't think they will cover up too much but as I don't know their exact position yet I feel it is safer just to do the whole thing... Cool .. Same can be said about the red stripe along the side and of course the blackened top of the hull... Have been thinking of using artists ink on this areas as their thin application will allow the grain of the wood to show through plus of course the trenailing..(I hope)...My real concern here would be the ink bleeding onto area's I don't want it to go on to.... Lots of things still to ponder over as I fully intend to trenail the whole of the lower hull as well....Cool Cool .. I must be bonkers....LOL LOL .. Any advice would be greatly appreciated....Blink Blink
Thanks again
Regard
NMBROOK
#953 Posted : 21 May 2013 20:15:16
Hi Alan, just thinking about your red stripe.You could use Paduk.This is available from CMB and is naturally red in colour.Their picture doesn't really convey this,but I have seen it used for gunport linings with great effect.You could use red indian ink on limewood strips.You would probably have to fit them between your wales after staining,otherwise the ink is liable to bleed into everything.
Just a couple of suggestions for you to ponder.
Kind Regards Nigel
#954 Posted : 21 May 2013 21:55:10
Kind Regards Nigel
Thatks for that Nigel, gives me food for thought. Will have a look at CMB for Paduk and let you know what I think..... BigGrin BigGrin
Thanks again...
#955 Posted : 21 May 2013 22:27:55
Hi Alan.
That's a good suggestion regarding that Paduk (never even heard of it till then!)Blushing
I wouldn't recommend any form of ink for putting sharp edged lines across a wooden planked surface. The stuff will bleed everywhere (which of course is exactly what it's designed to do! hence the Citidel inks which are used as a wash for shadow effects on figures). Other than very careful masking the only other way that might be useful is the clear or white waterslide A4 transfer sheets available from various art stores on ebay. I used some of it to produce the blue stripes on the yellow ochre beakhead timbers. You just paint it the colour you want, acrylic or enamel and once dry just trim it to size and use like an ordinary waterslide decal.
Its also really good for painting intricate designs onto for stern decorations etc.
Best of luck with the Porcupine of the Seas as she's been called!BigGrin
Everybody else is doing the SOTS you're doing the POTS! LOL
#956 Posted : 21 May 2013 22:49:41
Plymouth57 wrote:
Hi Alan.
Hi Robin, thanks for that and you have just confirmed what I have been thinking with the use of inks, the bleeding makes their use a little too risky.... Have been onto CMB and had a good look at Nigels suggestion on the use of Paduk... lovely wood but the thinest they do is 1mm so not sure if it will be suitable in this instance.... Cool Cool .. More food for thought..... at this rate I will turn obese....LOL LOL LOL
#957 Posted : 21 May 2013 22:51:04
Kind Regards Nigel
Thanks again...
Hi Nigel, loved the suggestion but the thinest is 1mm, that just may be a little too thick for my liking.... Cool Cool ..More thinking to do....BigGrin BigGrin
NMBROOK
#958 Posted : 22 May 2013 01:13:19
Hi Alan,the same place that I got the black boxwood from does coloured veneer.They do two different shades of red.This is 0.6mm thick,however you will have to cut into plank widths yourself.
Kind Regards Nigel
#959 Posted : 22 May 2013 10:04:25
BigGrin Hi Alan
Inks are a good way of staining wood but the wood will need to be stained before cutting and fixing in place, venear's are also another way to go but if the colour is not right then it will niggle every time you look at it. What you must also consider that the position of the model after finishing as displaying in direct sunlight will fade the inks and natural colored venear's very quickly. hope this helps
NMBROOK
#960 Posted : 22 May 2013 12:20:10
Message was deleted by User.
Guest (6)
This page was generated in 0.756 seconds.
