Joined: 25/03/2013 Posts: 204 Points: 620 Location: Kajang , Selangor , Malaysia
Thank Mr T , Thank Mike , Thank Alan Current build - D51 locomotive Completed building the H.M.S Victory Now collecting the Senna McLaren MP4/4
More on the hull planking yzwong attached the following image(s): Current build - D51 locomotive Completed building the H.M.S Victory Now collecting the Senna McLaren MP4/4
 looking good Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Joined: 20/10/2010 Posts: 511 Points: 1,459 Location: Loughborough
Nice build yzwong. Keep up the good work. Peter Builds in progress: HMS Victory.HMS Surprise. Completed builds: Revell London Bus 1/24. Builds to do:Sovereign of the seas, Hms Albion.
Hi yzwong, really nice to see the old girl starting to take shape.....  ..Very nice work there..... Regards Alan
Nice thank to all of you guys. Gun ports cont..... yzwong attached the following image(s): Current build - D51 locomotive Completed building the H.M.S Victory Now collecting the Senna McLaren MP4/4
Exceptionally clean and accurate work Kind regards Nigel
Impresive work Yzwong, very neat and tidy building.... Very well done to you.... Regards Alan
Thank Nigel , Thank Alan My build cont.... yzwong attached the following image(s): Current build - D51 locomotive Completed building the H.M.S Victory Now collecting the Senna McLaren MP4/4
 Hi Very tidy and neat job there Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Thank Andy More on the gunport yzwong attached the following image(s): Current build - D51 locomotive Completed building the H.M.S Victory Now collecting the Senna McLaren MP4/4
Hi , can anyone help ?????????? Which issue or how can i obtain this card template that use as a guide Below is a picture of it in issue 31. yzwong attached the following image(s): Current build - D51 locomotive Completed building the H.M.S Victory Now collecting the Senna McLaren MP4/4
The template is made in issue 24.
Greetings Lucien
Hi , Lucien , Thank for your reply but are you sure is issue 24. I had check and can't find anything about card template.If possible can you post a picture of it. Thank again Current build - D51 locomotive Completed building the H.M.S Victory Now collecting the Senna McLaren MP4/4
Hi Yzwong. I checked again and on the Belgium Deagostini website the template is made in issue 24. (See this link) If you look at the official build here on the website it is also made in issue 24 (see this link, post nr.6). Look trough your subscription magazine again, it should be there. Greetings Lucien
Looks great. Will look wonderful when you sand her down. Are you staining, painting or coppering?
John
Thank John, As for her , I wait until complete planking the hull first. Current build - D51 locomotive Completed building the H.M.S Victory Now collecting the Senna McLaren MP4/4
Hi, Lucien , Thank again for your quick reply I think I know what is wrong. It's the issue problem but anyway I think I can print out from your link and hopefully the template is the same size. Here is some picture of my issue 24. yzwong attached the following image(s): Current build - D51 locomotive Completed building the H.M.S Victory Now collecting the Senna McLaren MP4/4
Hi Yzwong It does seem that your issues differ from ours. I did a quick check and your issue 24 is the same as my issue 23. So it could be the template is in your issue 25. Might be a good idea to look through your issue's from 25 and above. It cant be very far off and should be somewhere in the magazine. In case that you cant find it, i took the measurements for the template. So that when you print it out you can check if it is the right size.  Greetings Lucien
Hi, Lucien , thank you very much As for the card template , I Had double check issue 20 - 32 and there is nothing about it. I already print out a copy of the template and the measurements is smaller varies from 2mm to 5mm in size. I think some enlargement printing has to be done. Anyway I can still go on with my builds without using the template. Again thank for your time and effort YZwong Current build - D51 locomotive Completed building the H.M.S Victory Now collecting the Senna McLaren MP4/4
Guest (12)
